2006 Reno Head torque - Suzuki Forums: Suzuki Forum Site
Old 07-31-2008, 10:52 PM   #1 (permalink)
ravenkil is on a distinguished road
Default 2006 Reno Head torque
Has any one here torqued a head on a 2006 reno? I have a print out from the local dealer and it says Tighten the cylinder head bolts to 18 ft. lbs. (25 Nm) and turn the bolts another 3 turns of 90 degrees using the angular torque gauge. I torqued them to the 18 pounds then went over all of them 1 time doing the 90 degrees. From my understanding i was going to hit each bolt 3 times for 90 degrees but when i started the 2nd time it just seems way to tight for an aluminum head. I put my digital torque wrench on the degree wheel and set it at zero and before the angular gauge moved i was over 60 ft lbs. I'm thinking 90 degrees two more times would be way too tight. Any help would be appreciated!
ravenkil is offline   Reply With Quote Quick reply to this message
Old 08-12-2008, 06:33 AM   #2 (permalink)
I had ordered new head bolts but when they arrived they were the wrong ones. I tried to get away with using the old ones. Well, these head bolts are stretch bolts so i went to the dealer and got the correct bolts and torqued to specs. This engine is one of the easiest head gaskets i have every done.
