For those having TPS issues, here is a diagram and description of it's function, etc. (Taken from ALLDATAdiy.com) Keep in mind, on '06 (and later, I believe), if the TPS is your problem, the entire throttle body must be replaced. Just had to have it done on my '06 Forenza.
Circuit Description
The Throttle Position (TP) sensor incorporates 2 TP sensors into one housing. TP sensor 1 and TP sensor 2 each have a 5 volt reference circuit supplied by the ECM. The ECM supplies each TP sensor with a low reference circuit. Each TP sensor supplies the ECM with a signal voltage that is proportional to the throttle plate position. The TP signal voltages are opposite from one another. TP sensor 1 is pulled up to reference voltage as the throttle plate is opened. The TP sensor 2 is pulled down to low reference as the throttle plate is opened.
Conditions for Setting the DTC
* Ignition ON.
* Difference between normalized values of TPS1 and TPS2 is greater than expected for a certain period of time.
Action Taken When the DTC Sets
* The Malfunction Indicator Lamp (MIL) will illuminate.
* The ECM will record operating conditions at the time the diagnostic fail. This information will be stored in the Freeze Frame and Failure Records buffers.
* A history DTC is stored.
Conditions for Clearing the MIL/DTC
* The MIL will turn OFF after four consecutive validation cycle in which the diagnostic runs without a fault.
* A history DTC will clear after 40 consecutive warm up cycles without a fault.
* The DTC(s) can be cleared by using the scan tool.
Diagnostic Aids
* Inspect the ECM connectors for signs of water intrusion. When water intrusion occurs, multiple DTCs could be set with no DTC circuit or component conditions found during diagnostic testing.
* When the ECM detects a condition within the TAC system, more than 1 TAC system related DTC may set. This is due to the many redundant tests that run continuously on this system. Locating and repairing 1 individual condition may correct more than 1 DTC. Disconnecting components during testing may set additional DTCs. Keep this in mind when reviewing the Capture Info.
