2006 Forenza- OBD2 DLC Communication Issues - Suzuki Forums: Suzuki Forum Site
Old 10-23-2017, 01:01 PM   #1 (permalink)
dsrt_zuki is on a distinguished road
Default 2006 Forenza- OBD2 DLC Communication Issues
Hi All,
I have a 2006 Forenza that I am having issues with connecting a scanner to. There is power through the scanner to pin 16 (12 V) but I cannot get it to communicate with the ECM. I am sure it's not the scanner as I have plugged it into other cars and it works just fine. I have tried the following;
1.Made sure all the fuses, both in the engine compartment and instrument panel boxes, were all good.
2. Checked voltages and resistance/continuity at the DLC pins
When I checked voltages at the DLC everything seemed ok, except I have some questions for my pin 7 readings. At pin 7 with key in OFF position I was getting essentially 0 V, with Key in ON position I was getting about 8.5 V. Does anyone know what the voltages should be?
Any other troubleshooting ideas? Thank you.
dsrt_zuki is offline   Reply With Quote Quick reply to this message
Old 10-23-2017, 02:13 PM   #2 (permalink)
aquanaut20's Avatar
Is the scanner powering up?
Or, was the pin 16, just tested for the Bat+..
... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 10-23-2017, 04:40 PM   #3 (permalink)
Hi aguanaut20 thanks for replying.
Yes, the scanner powers up. There's an LED that lights up when I first insert it into the DLC, and it also blinks as it attempts to connect/communicate with the ECM. After this I just get a "No response" message.
Old 10-23-2017, 05:09 PM   #4 (permalink)
aquanaut20's Avatar
I do not have a schematic for your ECU, but most require 2 power and 2 grounds, missing just one will stop comms..
... Philip
