help needed 2006 forenza code p0502 - Suzuki Forums: Suzuki Forum Site
Old 01-24-2017, 10:48 PM   #1 (permalink)
jdiego74 is on a distinguished road
Default help needed 2006 forenza code p0502
hi there.. I have a 2006 forenza and keep showing code p0502,,, speedometer works fine but I don't have speed reading on scanner does any one here had the same problem?? already try 2 ecm and still same issues....
jdiego74 is offline   Reply With Quote Quick reply to this message
Old 01-25-2017, 05:17 PM   #2 (permalink)
aquanaut20's Avatar
Wondering why you would start by replacing the most expensive part..
Would you consider checking the speed sensor on the transmission and the associated wiring?
... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 01-26-2017, 08:41 PM   #3 (permalink)
well I did check for signals al vss plug.... ground 12v. and 10v signal from ecm where present at the plug... did also check wiring diagram from alldata and cluster uses same signal from vss and pin 38 at ecm ... did check continuity on all wires all test ok w/no short to ground or power... wonder if alldata diagram it accurate lol how I said cluster works but ecm does not read speed and both uses same signal from vss....
