2 Recalls; One major one not - Suzuki Forums: Suzuki Forum Site
Old 11-05-2007, 04:42 PM   #1 (permalink)
Default 2 Recalls; One major one not
When I took my car in today for maintance I found out there where two recalls for my car (2005 Reno). One was a water pump inspection which lead to the infamous belt being fix, and the other was replacing some wire for the head lights as I guess it burns out. I knew the belt for the water pump was a killer for a car as if that goes our engine goes. But from what I have read it should have lasted me to 60k milies and I am little over half way.
jurupa is offline   Reply With Quote Quick reply to this message
Old 11-05-2007, 06:27 PM   #2 (permalink)
itschuck is on a distinguished road
The problem was the belt was to close the pump. I had ours done at 10k. They did the belt and water pump and then had to order a tensioner as the one on the car fell apart in the mechanics hands.
The wire problem is a chaffing issue where its routed thru the left fender, the wire grounds against the fender.
itschuck is offline   Reply With Quote Quick reply to this message
Old 11-06-2007, 05:57 PM   #3 (permalink)
SuzukiTech
The water pump one is correct, the belt rubs to the inside of the pulley and breaks the pulley, which in turn shreds the belt and bends the valves. With a redesigned water pump you should inspect the belt at 30K replace at 60K
The Wire issue for the headlights is not caused by the wire rubbing on the inner fender. its a junction plug behind the gauge cluster that burns up. Simple fix, cut 3 wires, connect them together and heatshrink them and your good to go.
SuzukiTech is offline   Reply With Quote Quick reply to this message
Old 11-06-2007, 06:55 PM   #4 (permalink)
My bad it was this one I was thinking anout..
Electrical - Forenza, Reno - Many Electrical Problems
Section Title: Body, Cab & Accessories
TSB No.: TS 08 08115
Division: Automotive
Category: Technical
SUBJECT:
WIRE HARNESS INSULATION DAMAGE BEHIND THE LEFT FRONT FENDER LINER
MODEL(S):
FORENZA SEDAN/WAGON, RENO (RQ420)
YEAR:
2004-2005
CONDITION:
Certain electrical circuits may not operate.
CAUSE:
Some of the wire insulation may have been damaged during assembly at the factory. This allows moisture to penetrate into the wires. The moisture can corrode the wires inside the insulation which could cause a short or open in various electrical circuits.
