2006 Forenza flickering lights/only when running - Suzuki Forums: Suzuki Forum Site
Old 07-20-2016, 12:00 PM   #1 (permalink)
b.wedmore is on a distinguished road
Default 2006 Forenza flickering lights/only when running
My dads forenza has a problem. ALL THE LIGHTS flicker when it is running. it doesn't do it when it is off. had the alt tested at parts store said it was good. Has anyone had this issue, I have seen other threads but they were not the same issue.
Is there a ground wire I am missing? checked them to make sure they were tight and not corroded. I am at a loss. I told him not to buy this car and now I am the one fixing it.
Thanks for any help.
Bryan
b.wedmore is offline   Reply With Quote Quick reply to this message
Old 07-20-2016, 12:15 PM   #2 (permalink)
Default sorry it should say!!!
It should say when the motor is off the lights do not flash.
Old 07-23-2016, 08:14 PM   #3 (permalink)
aquanaut20's Avatar
That would indeed be an alternator issue, either a rectifier diode is bad or the load is no good (battery).
The alt case is the ground via the engine>frame>body... Check the ground for voltage drop.. >.3vdc with loaded circuit is poor...
... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 08-16-2016, 11:03 AM   #4 (permalink)
SuziSuzuki is on a distinguished road
Default wiring harness recalls
This year Suzuki has multiple recalls for the wiring harness, specifically for exterior lighting. If you haven't received a notice you can probably look it up online. Get it fixed for free!
SuziSuzuki is offline   Reply With Quote Quick reply to this message
Old 11-28-2016, 01:53 PM   #5 (permalink)
SeanNeimo is on a distinguished road
This guy nailed it! /\ /\
SeanNeimo is offline   Reply With Quote Quick reply to this message
