P0303 - Suzuki Forums: Suzuki Forum Site
Old 04-10-2016, 12:11 AM   #1 (permalink)
ferny12 is on a distinguished road
Default P0303
Has any one had the code Po303 iam going to check the cylinder #4 misfire for a bad sparkplug or maybe the coil pack went bad?
ferny12 is offline   Reply With Quote Quick reply to this message
Old 04-11-2016, 05:14 PM   #2 (permalink)
I fixed the code Po303 it was oil in cylinder replaced valvecover gasket was bad
Old 04-12-2016, 07:49 PM   #3 (permalink)
Poker is on a distinguished road
I think your head gasket is likely failing (because you recently posted overheating and blowing hoses). I just went through this with an 06 Chevy Optra (Canadian version of the Reno). Started off running hot, would have to add a small amount of coolant every few days. Then occasional misfire on cylinder 4, also oil in the cylinder. No sign of coolant sludge on oil fill cap.I also replaced valve cover gasket and then did a compression test and all looked ok. But still losing small amount of coolant and occasional misfire. Was about to due a leak down test because I suspected head gasket. Catastrophic head gasket failure occurred before I got to it. (This was a friends car).
From first symptom to full failure was about 2 months.
After a Google search it turns out this is very common for the car usually occurring between 90 to 120,000km. Most start slow with these exact symptoms, coolant loss, overheating and misfire on cylinder 4.
Poker is offline   Reply With Quote Quick reply to this message
