external oil pump priming - Suzuki Forums: Suzuki Forum Site
Old 12-09-2015, 08:11 AM   #1 (permalink)
Osaga is on a distinguished road
Default external oil pump priming
I have a 2004 forenza (Chevy Optra) with 85k miles on so figured its still worth to put money into it... the oil light would flicker once in a while when engine is warmed up and at idle plus the head gasket was leaking coolant.. I wanted to do it all in one shot - new gasket set, timing belt, tensioner, water pump and the oil pump... once I removed the timing back cover, I seen that the oil pump gasket was blown and sticking out and everything on that side covered with oil... the new pump that I got was the wrong one - everything bolted the same but the pickup tube was different place.. I took the chance assuming it was only the gasket causing low oil pressure so I put the new gasket and reused the old pump since no local shops had one and I didnt wanna wait to order new pump... so, now its all put back, I drove around the block and just before the driveway low oil light came on.. steady on... the oil filter did have oil it it so it must have primed a bit.. I guessing there was an air bubble and lost prime???
I tried a mechanical oil pressure and it doesnt even budge, removed the filter and cranked it without plugs and nothing comes out... I even tried placing a tube with a fitting in the sensor hole and tried suking oil out but only air (assuming from the top).. Im still pretty sure its only priming issue..
anyone with ideas? suggestions??
Osaga is offline   Reply With Quote Quick reply to this message
Old 12-11-2015, 08:51 AM   #2 (permalink)
exist3nce's Avatar
Gallery: 9
The oil pump should be able to prime itself, sucking up the oil from the pan. Perhaps the gasket doesn't match or is installed incorrectly? You probably have to take it apart again to inspect...
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
Old 12-11-2015, 01:58 PM   #3 (permalink)
thanks.. I ordered a new pump.. gonna redo it again
Old 12-15-2015, 11:52 AM   #4 (permalink)
oh found the problem... quite embarrassing... when I was wiping it down,, I guess a piece of the rag ripped off and got stuck to the pickup tube... now its all back together and seems to be running great
