reverse grind - Suzuki Forums: Suzuki Forum Site
LinkBack Thread Tools
Old 03-12-2007, 12:54 PM
ace184's Avatar
ace184 is on a distinguished road
Angry reverse grind
so lately, my car has been grindin when i try to put it in reverse. it dont happen all the time, but it shouldnt happen at all. its almost as if my master cyclinder in bleedin, b/c if i pump the clutch, itll work better, but still grind........im not on a hill or anything, perfectly flat........is it the master cylinder or sumtin else? anyone else have this problem?
FYI-2006 forenza 5 speed with 7000 miles
ace184 is offline   Quick reply to this message
Old 03-12-2007, 01:19 PM
every once and a while i have that problem. i put it in neutral and let the clutch out and then try again and it seems to work fine...it might have something to do with the trans spinning/not spinning while trying to put it into gear.....similar to downshifting to first. your trans doesn't want you to shift down too early(safety feature).
tallkid is offline   Quick reply to this message
Old 03-12-2007, 03:31 PM
kinkyllama's Avatar
I think its just cuz we dont have sychros in reverse. So double clutching should cuase it never to grind. Otherwise I doubt the grinds hurting anything or they would have had to use sychros.
[size=2][b][url=http://autoinsurances.wearecares.net]Best Auto Insurance[/url] | [url=autoprotection.wearecares.net]Auto Protection Today[/url] | [url=trade-in.wearecares.net]FREE Trade-In Quote[/url][/b][/size]
kinkyllama is offline   Quick reply to this message
Old 03-12-2007, 03:42 PM
Your clutch isn't FULLY disengaging. It's the clutch M/C problem by the sounds of it. Shift into a forward gear 1st, then quickly to reverse. That may help for now (that will stop the gearing from spinning).
If you hadn't said that the M/C was needing pumping up, then I would have suggested pedal linkage adjustment.
Max is offline   Quick reply to this message
Old 03-12-2007, 05:25 PM
TTGOTH's Avatar
TTGOTH is on a distinguished road
What he said, Every 5 speed i have owned has done that. You can feel if it's going to grind before it does, So if that happens let the car roll an inch or two then try it. As for me it's normal for a 5 speed.
[url]http://tt-goth.blogspot.com/[/url]
TTGOTH is offline   Quick reply to this message
Old 03-12-2007, 06:25 PM
Zipper's Avatar
Gallery: 28
This tranny is just known for that. If it dosn't want to go in, don't force it. Just put it into Nutrual, let your foot off the clutch, then try again. It should work this time
Just a quirk. Nothing big
[URL="http://www.cardomain.com/ride/2426202"]04 Suzuki Forenza![/URL] [URL="http://www.cardomain.com/ride/2641372"]68 Dodge Dart!![/URL]
[URL]http://tamedracingdriver.com/stigfact.php[/URL]
[IMG]http://tamedracingdriver.com/stigfactsig.php[/IMG]
Zipper is offline   Quick reply to this message
Old 08-28-2007, 01:40 AM
evotistical's Avatar
evotistical is on a distinguished road
yea both my renos do this its kinda normal, just dont "slam" it into reverse
evotistical is offline   Quick reply to this message
Old 08-28-2007, 08:30 AM
hydr0san is on a distinguished road
yep mine does it too, double clutching usually does it
hydr0san is offline   Quick reply to this message
