Reno randomly doesn't start - Suzuki Forums: Suzuki Forum Site
Old 05-11-2015, 10:22 PM   #1 (permalink)
tvitale is on a distinguished road
Default Reno randomly doesn't start
My 2005 Reno has a hard time starting, randomly. Took it to a shop and they couldn't duplicate. The darn thing cranks but won't fire. There isn't any pattern. It might act up today but not tomorrow might go a week maybe 2 maybe a month maybe everyday.
It does eventually start you just don't know how many tries.
Plugs and wires have been replaced. Was thinking about a coil but I don't want to just throw parts in it. Any help would be appreciated.
tvitale is offline   Reply With Quote Quick reply to this message
Old 05-29-2015, 10:45 PM   #2 (permalink)
Anyone have an idea?
Old 05-30-2015, 12:11 PM   #3 (permalink)
P1NkY is on a distinguished road
Too little information to be able to diagnose, I'm afraid.
Is the check engine light on? Any codes that might help us troubleshoot?
It could be a failing sensor or something, but if you don't pull codes it is near impossible to tell.
After cranking for a while without start, have you checked if the plugs are wet with fuel, which would indicate lack of spark?
If they are dry, you might have a fuel delivery problem instead. In that case, have them check for adequate fuel pressure. It might be as simple as a clogged fuel filter.
Is there a distinct smell of fuel anywhere around the vehicle? A loose connection or hole in the fuel lines can cause the fuel to drain back into the tank. Startup would take much longer, as the pump has to fill the lines and re-pressurize the system.
Sorry I couldn't be much help.
P1NkY is offline   Reply With Quote Quick reply to this message
Old 06-03-2015, 08:50 PM   #4 (permalink)
No codes, I havent checked the plugs when it dosent start because it is so random it never seems to happen in the morning when the car leaves home, but might happen after driven 15 miles to the university or from there to job you just never know. Asked my daughter if she would mind pulling the plugs when it happens and she didnt feel like that was something she would want to do. I had her leave it home for a couple days and it didnt fail took it to shop for a couple days no fail there either. The car has 90k on it maybe fuel filter is needed I was thinking it is in the tank I will check.
Thanx for the reply anything else would be appreciated
Old 08-04-2015, 10:20 AM   #5 (permalink)
Update on reno. cel did come on a couple weeks ago. had codes chkd they were P0507,P2279,P0420.
Found vacuum leak on egr adapter gasket. replaced gasket no more engine light no starting issue, until 2 days ago when it wouldn't start and again hasn't had an issue since then. Anyone ever have this intermittent problem? Sure could use some ideas on this one.
