2005 reno over heating with no signs of a leak - Suzuki Forums: Suzuki Forum Site
Old 04-13-2015, 02:35 PM   #1 (permalink)
stchuna is on a distinguished road
Default 2005 reno over heating with no signs of a leak
I replaced the oil sending unit that was part of the problem.
The car is over heating?
the cooling system is not giving me any signs of a leak. There are no puddles and no signs of a broken hose. There is no sign that it is leaking into the oil. Nothing.
Yet it is always out of fluid.
at idle it is fine I left it idle for an half hour trying see a leak nothing took it for a spin around the block and it jumps to red hot in the blink of an eye.
any ideas what is up.
I have owned the car for 3 years and not one problem out side of a broken cam shaft. a truly great car. But I am stumped
Thanks in advance
Shannon
stchuna is offline   Reply With Quote Quick reply to this message
Old 04-14-2015, 06:36 PM   #2 (permalink)
exist3nce's Avatar
Gallery: 9
So idling for 30 min it does not overheat? Do the fans cycle on and off?
You can try to look in the coolant reservoir while the engine is running to see if the coolant is swirling and circulating around - it should be visible moving around and circulate faster if you rev it up a bit... Just don't open it while the engine is already very hot. I had a water pump go bad a few years ago where the plastic impeller separated from the metal shaft - It would pump the coolant around somewhat while the engine was cool, but as it warmed up it pumped less and less.
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
Old 04-15-2015, 11:40 AM   #3 (permalink)
yes both fans are on and working.
I will check the coolant Thank you for your reply
Shannon
