just cant get it to time please help - Suzuki Forums: Suzuki Forum Site
Old 11-16-2014, 05:49 PM   #1 (permalink)
jonathan_flowers is on a distinguished road
Unhappy just cant get it to time please help
2004 chevy optra 190xxx about 5000 km ago changed water pump and timing belt... didnt know idler pulleys should have been done aswell. pulleys started to make noise after a bit..new belt more tenson etc im assuming..... 4 days ago dring up a back mountain rd to have some rally fun. pulley made more noise then normal. So i get out and proceed to change it.... i was in such a hurry i forgot to mark everything.... i change pulley bring piston one to tdc and line up the cams as norm.... turn key nothing ... turn agian nothing
i adjust try etc prob about 20 times now.... friend comes and looks says im 180% off so i go and fix,,, now there is still nothing... will some time s back fire but nothing.... car was running when i shut it off just was being cautious.... so it hasnt ran since i shut off and if i was out like 180% on the dot prob not bent valves... i still have compression .... please help im exhausted and have no more ideas
jonathan_flowers is offline   Reply With Quote Quick reply to this message
Old 11-16-2014, 06:51 PM   #2 (permalink)
pics of where every thing sets as is rotated cranks twice using 17mm wrench was all good so tried to fire it up this is where my marks are after all that and moving the marks to check once again for the forth time
just cant get it to time please help-20141116_150324.jpg   just cant get it to time please help-20141116_150333.jpg   just cant get it to time please help-20141116_150417.jpg
Old 11-16-2014, 06:53 PM   #3 (permalink)
that faint red mark with like sharpie?
Old 11-16-2014, 11:13 PM   #4 (permalink)
Have you checked where the marks line up in the service manual? I can't see any matching marks on the heads anywhere near the cam marks in your pics
Old 11-17-2014, 05:42 AM   #5 (permalink)
sorry the pics are rotated to the left. its at the top in black the lil arrrow on the back of the timing cover i can repost with a circle around them.... to bad u cant upload 4k pics would be way easier to see
Old 11-17-2014, 05:49 AM   #6 (permalink)
there sorry about that see if this helps is it possible that one cam may be out 180* if so how can i actually telll my intake was back firing threw the trottle body so i knew that was out 180 so i just locked both cames then spun the crank 1 revolution..... those marks aint perfect but even still it should still start. i may be out one tooth at most.... it sputters some times usally when i first try like it wants to start but just wont then after that nothing unless i let it sit for an hour or so then same thing...
Old 11-17-2014, 05:54 AM   #7 (permalink)
this is one a the few i looked at they are generally all the same even though i have a 2.0l not an 1.8
Old 11-19-2014, 08:10 AM   #8 (permalink)
Gallery: 11
hi.ok so your first problem is this. your car has an interfearence motor. the short of it is, you cant move the bottom without moving the top. if you need to only move the crank you need to remove the cams first so the pistons dont get forced up into the valves. theres really no way to know what damage there may be, if any at all, without pulling the head. stop trying to start the car. that can cause damage at this point. so what would i do. probably cry out of frustration lol then i would remove the cams and reset the bottom end to TDC then set the cams. the tensioner can be a real pain to set and will probably taqke a few times to get dont right. hopefully thatll get everything working as it should. let us know what happenes. anything else just ask
Old 11-20-2014, 05:16 AM   #9 (permalink)
Sadly i didnt know you cant turn the crank with out the cams... either way i tried both ways still no dice. i have narrowed it down to i think either a fuel issues or my valves got fucked from trying to start it.... i had a mobile car technician come look at it he told me turning it over while trying to get the timing right wouldnt hurt the valves.... i told him it was interference and argues with him as he wanted to turn over the motor... he has been cerified for 27 years blahg blah so thats why i keep trying to start it cause he convinced id be fine... now as for the fuel issue... when i turn the key to on i do hear the fuel pump kick in for 2 seconds... now the pressure release valve net to the injecter it will spray some fuel (when pressed) after the system is charged... but not as much as one would think. from what i know its 40 -60 psi.... from the few drops i get in a quick mist i think its not up to par.... also if i spray wd 40 in the throttle body or a bit of gas the car does sputter ( not start) then will continue to turn over with nothing till i spray it again.... also i car does have spark cause i had a back fire and a nice big flame come out from two much wd40.....
Old 11-20-2014, 05:20 AM   #10 (permalink)
the crank was only turned when the cams where set to tdc or attached to the cams so even if i was out 360 degrees on the crank would my valves not be hurt at all? also the fuel issues is a pain cause i just changed it 2 months ago and the smell of fuel in the car stayed in there for almost a month... sadly i was broke at the time to i had to get a used fuel filter
