HELP!!! 2007 Forenza- Turn Signals&Dash Lights - Suzuki Forums: Suzuki Forum Site
Old 09-22-2014, 08:50 AM   #1 (permalink)
kristuhhh is on a distinguished road
Unhappy HELP!!! 2007 Forenza- Turn Signals&Dash Lights
I just bought a 2007 Suzuki Forenza for super cheap. It had been hit in the front end. I replaced all of the parts and am now driving it. I have 2 problems with the car.
1. The turn signals and the hazards are not working. They do not work on the instrument cluster as well as both front and back flashers. I have replaced the fuses, changed the switch its self and changed the relays up under the drivers dash! Still no turn signals or hazards! Not sure if this is a combination problem or 2 different problems.
2. The air bag light, battery light, C/E light, power steering light, & brake lights are all illuminated on the dash. I have ran codes on the car many times. I always get ONLY ONE code P0113. (IAT sensor). Trying to figure out why all of those lights are on. Was told by the person I bought it from that it was a ground wire that needed fixed..?
I only have 700$ tied up in this car. It runs and drives fine but I do not have signals or hazards and all of those lights are on and i dont know what else to do..PLEASE HELP!!! Thanks!
kristuhhh is offline   Reply With Quote Quick reply to this message
Old 10-01-2014, 03:46 PM   #2 (permalink)
DamnCampers is on a distinguished road
If I remember correctly there is a recall pertaining to the wiring behind the instrument cluster that might or might not affect those. I don't remember which years that the recall covers so it might be worth having it looked at to see if the recall has been completed.
Ask your local auto parts store what an IAT sensor is and where it might be located. They normally won't be able to tell you where it is exactly, but knowing where to find it will help you locate it in the service manuals so that you know what you are looking for.
DamnCampers is offline   Reply With Quote Quick reply to this message
Old 10-04-2014, 07:53 PM   #3 (permalink)
Gallery: 11
hi. first off the iat sensor is located in the intake tubing of the car. now for the other issues. the airbag light might be on because of a faulty airbag sensor inside the passenger seat, a common problem on the reno/forenza. its also possible you have a bad power steering modual, ssps i think they call it. as for the brake lights first check and make sure theyre all working and none are out.if you changed fuses and such then youll have to start checking wiring. there is a recal on the splice pack behind the gauge cluster but i dont think that goes to your year, not sure. honestly what i would do is call the person you bought the car from and find out excactly what ground is loose or bad. save yourself hours and hours, or lots of cash if a mechanic has to look, trying to track it down.
Old 10-04-2014, 09:02 PM   #4 (permalink)
most common grounds to cause these issues are the main one by the fuse box on the drivers side panel, and the ones up by the lights. Check the ones under the hood, since its had a collision, chances are theres a ground missing in the front of the car. Check the one near the relay / fuse box under the hood too.
I'd get the lighyts going first and you might just find the IAT fault may go as well, bad grounds can cause all sorts of crazy issues.
