crankshaft position sensor - Suzuki Forums: Suzuki Forum Site
Old 07-25-2014, 11:05 AM   #1 (permalink)
kayfranka is on a distinguished road
Default crankshaft position sensor
if any body know where is the location of a cranshaft position sensor in 2005 suzuki forenza ? thanks
kayfranka is offline   Reply With Quote Quick reply to this message
Old 07-25-2014, 01:12 PM   #2 (permalink)
cranshaft
Or Crankshaft?
Sandwiched between the engine and trans, BUT they seldom fail.
There is a Service Manual link in here to help you locate...
https://www.suzuki-forums.com/general...on-manual.html
Check the wiring to it and make sure you aren't hunting down the CAMSHAFT Position Sensor (both are known as a "CPS" in some circles).
So what is the problem in general?
Old 08-10-2014, 10:01 AM   #3 (permalink)
superhuman is on a distinguished road
I previously had the same complication a few days ago on my 2004 suzuki forenza. As a result, my CMP (camshaft position sensor) sensor needed to be replaced. So, I did some research and stumbled upon this Carfix: 2004 Suzuki Forenza check engine light code P0342 hope this helps 😀
superhuman is offline   Reply With Quote Quick reply to this message
Old 08-10-2014, 12:50 PM   #4 (permalink)
Sorry for my previous post, I was confused with the other cps sensor. Ignore my last post unless that is your problem.
Old 08-10-2014, 12:58 PM   #5 (permalink)
Yours is still good intel, as we are not 100% sure which CPS is in play here.
Crank or cam.
Old 08-17-2014, 08:46 PM   #6 (permalink)
SHAUN133 is on a distinguished road
the crankshaft position sensor is located behind the a/c and power steering pump bracket. the camshaft position sensor is located behind the cam gears and the access to remove the bolt is on the timing cover.
SHAUN133 is offline   Reply With Quote Quick reply to this message
Old 09-03-2014, 08:54 PM   #7 (permalink)
wintersagony22 is on a distinguished road
We are having trouble getting the camshaft position sensor off, any guidance would help is an 07 suzuki forenza
wintersagony22 is offline   Reply With Quote Quick reply to this message
