Can you identify this sound? - Suzuki Forums: Suzuki Forum Site
Old 06-14-2014, 09:24 PM   #1 (permalink)
Spaz is on a distinguished road
Default Can you identify this sound?
CIMG7680 - YouTube
2006 Reno. Has been making this sound on and off for 2 or 3 years now. Normally at start up until engine is warm. It will do it subsequent start up's sometimes. And sometimes it won't do it at all. At recent trips to the alignment shop and for state inspection the alignment guy said he thought it was the catalytic converter, and the inspection mechanic (who I know personally) rattled off a few things it might have been, but he couldn't say anything 100%. He guessed at oil pump, timing chain tensioner (I told him it was a belt and he ruled that out) and something else but I don't remember what it was because I think he ruled that out as well. The car runs fine and there are no warning lights/check engine light lit up on the dashboard. It can be embarrassingly loud sometimes and sounds like a diesel until it gets warm. Anyone else experience this? Any remedies or repairs? Thank you!
Spaz is offline   Reply With Quote Quick reply to this message
Old 06-16-2014, 10:44 AM   #2 (permalink)
exist3nce's Avatar
Gallery: 9
Whoa that's pretty loud... does it increase directly with revs? Does it change if you put load on the engine, like start to drive? From the video its hard to tell if it's something rattling like a heatshield, or possibly something touching one of the pulleys/belt on the accessory drive or even inside the timing cover. It doesn't sound like internal engine noise... I see your car is manual too - does it change if you push the clutch in at all ?
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
Old 06-16-2014, 11:47 AM   #3 (permalink)
I can't ID the sound either, but it is scary as hell.
Old 06-16-2014, 01:44 PM   #4 (permalink)
Actually, if you pump the gas in neutral, or actually drive it, the sound goes away. So I guess you could say as rpm's increase the noise decreases to a point where when it gets warm it goes away completely. It definitely seems to be directly relative to rpm's. It doesn't change when you push in the clutch. I do my own oil changes and have checked visible heat shields and belts, as well as the alignment guy and inspection mechanic.
I saw the subscriber who had an ignition switch problem in a Vitara. The one click guy with the YouTube video? It appears some Suzi's are prone to unexplainable phenomena/paranormal activity? Lol...
Thanks for the replies, all. Any other guesses anyone?
Old 06-16-2014, 01:50 PM   #5 (permalink)
Have you been using the recommended 5W-30 oil and changing it RELIGIOUSLY?
Look inside the opened oil fill port. Is the engine internally crapped up with black gunk or is it clean and shiny in there?
I'd remove the serpentine accessory belt and run the engine BRIEFLY to see if the noise goes stops, pointing toward an accessory (not engine) problem.
Old 06-16-2014, 02:13 PM   #6 (permalink)
Religious on the oil changes, about every 4K with the 5/30 Super Tech. No crud/build up in the valve train, all clean n' shiny. Before I go taking stuff apart I'll wait and see if anyone else cares to offer suggestions, but the accessory and serpentine belt suggestion seems like a sound one. Thanks!
Semi-proud Suzuki owner and AAA member...
Old 06-18-2014, 02:22 PM   #7 (permalink)
Gallery: 11
Have you had a look at the power steering pump? Sometimes the gears can start to go I think this might cause a noise. Also just looking at the heat shields isn't good enough. They can break free but still be held in place. You need to get under the car with a screw driver and check the connecting points of the heat shields to make sure there all intact. Let us know what you find out
Old 06-21-2014, 10:33 PM   #8 (permalink)
bcgipson is on a distinguished road
My 2007 Forenza manual is starting to make this same noise when the a/c is on. Did you figure out what was making this noise? Will be taken to the shop next week. Thanks for your help.
bcgipson is offline   Reply With Quote Quick reply to this message
Old 06-23-2014, 08:00 AM   #9 (permalink)
John M. is on a distinguished road
I had a similar noise... just not quite so loud. I finally found it by taking a long transmission funnel. And turning it around and making a hearing tube out of it. I finally found the noise loudest at/by gasket leak at the EGR valve sub-gasket (help me out with the correct name guys). The gasket that attaches the EGR/water hose/ sensor block to the head. The underneath of the gasket is only about 3/8" wide. And it had worn or blown out underneath the assembly. A huge amount of noise was blowing/sucking? out of a small leak.
John M. is offline   Reply With Quote Quick reply to this message
Old 05-10-2015, 08:09 PM   #10 (permalink)
Cocky Rocky is on a distinguished road
Sound has been ID'ed. It was the timing belt tensioner. This is my car and an old username I forgot the creds on. I just finished a t-belt n' water pump install and the tensioner was included in the kit. No more rattle. Sounds and runs really well now. I'll do a flush n' fill in a few weeks as soon as I know the WP isn't leaking as it's about 90% distilled water at the moment. I don't think we'll see any sub-freezing temps for awhile and summer ain't quite here yet...
Cocky Rocky is offline   Reply With Quote Quick reply to this message
