2004 Forenza that runs hot in the summer and cold in the winter - Suzuki Forums: Suzuki Forum Site
Old 04-23-2014, 03:50 PM   #1 (permalink)
jamied88 is on a distinguished road
Default 2004 Forenza that runs hot in the summer and cold in the winter
Hello I have a 2004 Forenza that has an over heating problem in the summer/spring and runs at half the normal operating temperature during fall and winter. When it over heats it is running at about 120 km/h and running at about 3500 rpms. This car has a standard transmission and has no a/c. I am beyond confused and frustrated with this thing and any help with it would be greatly appreciated. I am out of ideas!
jamied88 is offline   Reply With Quote Quick reply to this message
Old 04-23-2014, 04:01 PM   #2 (permalink)
Default With only those symptoms...
Blocked radiator fins, or crapped up internally (most likely).
If clogged up, a cheap fix...
2004 SUZUKI FORENZA Radiator
Old 04-23-2014, 04:04 PM   #3 (permalink)
Yeah but why is it running cold in the winter?
Old 04-23-2014, 04:44 PM   #4 (permalink)
What do you call "cold"? We could use some actual temps here.
Old 04-23-2014, 04:48 PM   #5 (permalink)
It runs at half of the normal operating temperature, never gets higher!
Old 04-24-2014, 08:43 AM   #6 (permalink)
exist3nce's Avatar
Gallery: 9
Could be a combination of things..
Running too cold is usually caused by a stuck open thermostat. A stat that is sticking or slow in any manner can cause both undercooling and overcooling - its a cheap place to start your investigation. I would try replacing this first.
Also as Max mentioned... you could have a clogged / dirty radiator that isn't transferring heat efficiently enough to keep the car cool when the temperatures are hotter outside. Combine a poorly functioning stat with this and it would create the problems you are talking about.
Have you ever put any of those "stop leak" (or any other) additives into your cooling system? They can really make a mess internally and degrade the overall efficiency of cooling.
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
Old 04-24-2014, 11:47 AM   #7 (permalink)
No I have never ran anything like that through it. I guess I will try the thermostat. I have repaired the Heater core in this car twice in two years and have struggled to get the air out of the system. Just seems like air just keeps turning up in my cooling system so I actually have had to loosen off my overflow cap just a touch so my system doesn't pressurize so much. Could this be attributed to some form of intake leak?
Old 04-24-2014, 12:18 PM   #8 (permalink)
Or cylinder head (combustion pressure) leak.
I still wouldn't rule out the radiator too, with regards to the high speed overheating. #1 cause!
Old 04-24-2014, 12:43 PM   #9 (permalink)
Something else that piques my curiosity is the need for you to have "repaired" the heater twice.
The core I assume, which leads me to believe that the coolant system has suffered from lack of anti-freeze maintenance (fresh inhibitors, flushed ever? resultant debris build-up).
Your thoughts?
How many miles on this vehicle?
Old 04-26-2014, 07:28 AM   #10 (permalink)
Well I have changed the heater core twice, first time may have been from a lack of maintenance and I think the second time may have been when I installed the heater core it was a real pain in the ass to get in so it was jammed in there pretty hard. So the antifreeze now has been changed several times since last winter. When you say combustion leak are you suggesting the head is cracked, head gasket blown or both? I have tried multiple times to purge the air from the cooling system but it just keeps finding it's way back in there. There is no antifreeze in my oil and I don't seem to be losing any antifreeze. I have right around 180000 km on this vehicle.
