OBDII Sensor is not receiving power - Suzuki Forums: Suzuki Forum Site
Old 03-04-2014, 08:32 PM   #1 (permalink)
Sinner's Avatar
Sinner is on a distinguished road
Default OBDII Sensor is not receiving power
Hey y'all, need some advice. My check engine light came on this morning, and when I went to plug the reader into the plug, I found that the OBDII has no power. I checked all the fuses on the drivers side dash, but none were blown. What else can cause this? Thanks.
All show with no go....yet.^_^
Sinner is offline   Reply With Quote Quick reply to this message
Old 03-05-2014, 09:28 AM   #2 (permalink)
exist3nce's Avatar
Gallery: 9
Possibly one of the pins has become dislodged/jammed/moved/pushed in. Have a look inside both connectors to check if any pins are abnormal.
Also you can use a multimeter to check if in fact there is no voltage present. Google for an OBD2 pinout to see which pins are power.
2004 Optra/Forenza/Lacetti - 225whp - Haltech Sprint500 - CT12B - Professional P&P - Getrag F28 6spd - KW V3 Coilovers - FX35 Retrofit
2002 IS300 5MT - 615whp - AEM EMS - GT4088R - Built 9.5CR - R154 - TRD LSD - SupraTT T/B - Varex - LS430 Retrofit
exist3nce is offline   Reply With Quote Quick reply to this message
Old 03-05-2014, 10:07 AM   #3 (permalink)
16 is +12v, 4 & 5 are ground.
Old 03-05-2014, 12:45 PM   #4 (permalink)
I'd first grab another Scanner to try on the chance that the plug on the one you used is connector finicky or the unit is simply broken.
Old 03-05-2014, 08:13 PM   #5 (permalink)
Sinner's Avatar
Thanks for the replies y'all...I wasn't able to take a voltmeter to it today, but I did try another scanner. It too failed to receive power. Upon physically checking the plug, nothing seemed jammed or broken, but tomorrow I'll take the voltmeter, use your info Fordem, and see what it says. I'll keep ya updated. Thanks again!
Old 03-10-2014, 03:41 AM   #6 (permalink)
Sinner's Avatar
So I managed to a voltmeter to it this past weekend. The two grounds you stated Fordem were fine after using an external 12 source; however, the main unit is still not receiving power. I checked all the fuses again and even briefly disconnected the battery, then reconnected, but nothing seems to work. Does anybody have any other suggestions before I'm forced to take it to the dealer?
Old 03-10-2014, 04:25 AM   #7 (permalink)
P1NkY is on a distinguished road
Here is the wiring diagram in PDF format.
Hope it helps.
P1NkY is offline   Reply With Quote Quick reply to this message
Old 03-10-2014, 09:32 PM   #8 (permalink)
Sinner's Avatar
Thanks Pinky, I'll see if I can't track the problem down.
