idle problem - Suzuki Forums: Suzuki Forum Site
Like Tree1Likes
  • 1 Post By P1NkY
Old 02-19-2014, 09:27 AM   #1 (permalink)
Imatouchstone is on a distinguished road
Default idle problem
I have an idle problem went through and replaced timing belt now everything seems smooth a few days after replacement the idle drops so low the car wants to stall out
Imatouchstone is offline   Reply With Quote Quick reply to this message
Old 02-19-2014, 11:52 PM   #2 (permalink)
Gallery: 11
hi. does it happen only when your at idle? or is the car driving rough? also what year is your car? my first guess would be the IAC valve, idle air control valve. they can get gummed up by engine blowby. you may be able to clean it. depending on what year your car is i can give you the directions on how to do it. let me know. anything else just ask
Old 02-20-2014, 12:31 AM   #3 (permalink)
It is a 2005 forenza and would that valve be locate in the repair manual and a friend told me about a mass air sensor im a complete novice at mechanics so it all sounds like rocket science to me
Old 02-20-2014, 09:49 PM   #4 (permalink)
Gallery: 11
hi. ok if its an 05 you could try to clean the IAC and see if that helps the problem. heres the link to how you can clean it.
https://www.suzuki-forums.com/suzuki-...-question.html
also heres the link to the online service manual
Daewoo Service Manual
its not all that hard to do if you feel like giving it a try. or else you could have the sensor replaced. either way let us know what happens.
Old 02-21-2014, 01:49 PM   #5 (permalink)
P1NkY is on a distinguished road
Hello and welcome, Imatouchstone.
You could also try an idle relearn. It's non-invasive (LOL) thus worth a shot:
Turn the ignition ON for 5 seconds.
Turn the ignition OFF for 5 seconds.
Start the engine in park/neutral.
Allow the engine to run until the engine coolant is above 185 F (85C ).
Turn the A/C ON for 10 seconds, if equipped.
Turn the A/C OFF for 10 seconds, if equipped.
If the vehicle is equipped with an automatic transaxle, apply the parking brake. While pressing the brake pedal, place the transaxle in D (drive).
Turn the ignition OFF. The idle learn procedure is complete.
Someone needs to make this procedure a sticky, I've posted it quite a few times, LOL.
sctaylor1969 likes this.
P1NkY is offline   Reply With Quote Quick reply to this message
Old 02-26-2014, 12:31 AM   #6 (permalink)
Gallery: 11
hi, any update? did you try the idle learn procedure that P1NkY suggested? thanks by the way P1NkY i always forget about that little gem. or any of the other suggestions?
Old 11-28-2016, 02:10 PM   #7 (permalink)
SeanNeimo is on a distinguished road
Default SOLVED intermittent stalling
My FIX : replaced the MAP sensor (64 bucks with new wire harness on Amazon)
located under the fuel rail, resolved my issue. Two 10mm bolts hold down the fuel rail.
and one E12 Female torx socket to remove bolt holding MAP sensor ( I used an 8mm 12 point socket ) to remove The bolt holding the MAP sensor
SeanNeimo is offline   Reply With Quote Quick reply to this message
Old 01-20-2018, 06:05 PM   #8 (permalink)
rloomis482 is on a distinguished road
Default ReLearn procedure "Q"
Want to try this on my "05" as well.
I hope someone will see reply, I know its been a while since it was started.
Question for member, P1NkY
When allowing to warm to 185deg, is this when the engine hits operating temperature. Not necessary for cooling fan to cycle once. or will the cycling not be required for the computer to complete the relearn once it hits temp.
I just want to be certain it reads it correctly.
Thank you for your time.
rloomis482 is offline   Reply With Quote Quick reply to this message
Old 01-21-2018, 03:19 PM   #9 (permalink)
? Wouldn't let me edit previous reply ?
One more question to procedure.
At end of procedure when you turn off engine...
Take out of gear P/N or just turn off in D (engaged).
I would assume to disengage "P" or "N".
I know it sounds like a stupid "Q" but it may need to read it as you described.
