Car will not turn over - Suzuki Forums: Suzuki Forum Site
Old 02-10-2014, 01:31 PM   #1 (permalink)
jamied88 is on a distinguished road
Default Car will not turn over
Hey Guys, 2004 Foenza 5 speed. Get to work this morning everything is good go to leave work and I have normal amount of power but the car won't turn over, no click no nothing. Acting like I have dead battery but it's not dead at all. I get somebody to come over and boost me (knowing it's not the problem) but when I pump the clutch it tries to turn over in small increments then finally it starts. Now I have it home and the same thing but not turning over at all. Could this be a safety neutral switch?
Update: With clutch pedal completely depressed call will not start but if I let it in and out and very short and fast intervals I can get it to start as long as I don;t let the clutch go all the way in or out. Very strange and would love to hear some thoughts on this.
jamied88 is offline   Reply With Quote Quick reply to this message
Old 02-10-2014, 02:01 PM   #2 (permalink)
P1NkY is on a distinguished road
Take a look on the clutch pedal shaft near the top. There should be a switch on it with two wires coming out of it; one yellow and one gray. This switch is going bad.
I can't give specifics about where the switch is exactly, as mine is an automatic and I can't find the switch in the manual anywhere but the wiring diagram (that's how I know it has a yellow and a gray wire).
***You can remove the switch and jumper the wires together, but you must be mindful that the car WILL start in gear even with the clutch out!***
This will allow you to use it in the meantime, but be sure to buy a new switch ASAP or try and disassemble the one you have and clean or repair it if so mechanically inclined.
P1NkY is offline   Reply With Quote Quick reply to this message
Old 02-10-2014, 03:32 PM   #3 (permalink)
If like the Vitara set-up, see...
https://www.suzuki-forums.com/1g-1999...-blackout.html
