Suzuki ATF 2384K? - Suzuki Forums: Suzuki Forum Site
Old 10-03-2013, 07:41 AM   #1 (permalink)
ogRe1985 is on a distinguished road
Default Suzuki ATF 2384K?
Recently i put a Mobil ATF 220 in my Suzuki Every 2009 model with K6A Engine and 3 speed auto.
Later on i saw Suzuki ATF 2384K on the dipstick which is not available in Pakistan.
So the question is whether i put a wrong oil in my vehicle or the Mobil ATF 220 meets the requirement of Suzuki ATF 2384K?
Can anybody give me the specification of Suzuki ATF 2384K?
ogRe1985 is offline   Reply With Quote Quick reply to this message
Old 10-03-2013, 06:59 PM   #2 (permalink)
newsavedone's Avatar
Gallery: 22
Greetings!
Mobil ATF 220
Automatic Transmission Fluid
Product Description
Mobil ATF 220 is a high performance, fluid for automatic transmissions in older vehicles specifying Dexron IID. It is also used as a hydraulic fluid in unique applications.
Features and Benefits
Mobil ATF 220 is formulated from high-quality conventional base oils combined with a special additive system including viscosity index improvers, antioxidants, and defoaments providing smooth and controlled friction/wear characteristics. The product provides consumers an excellent driving experience even in broad range of driving conditions in a wide variety of pre-1994 automobiles. Key features and benefits include:
Features Advantages and Potential Benefits
Good thermal and oxidation stability Resists lacquer, sludge and deposit formation to keeps transmissions clean for efficient operation over the fill life
Good anti-wear properties Meets the wear requirement to promote longer transmission life
Excellent low-temperature fluidity Assist in improved start-up and clean fast lubrication at low ambient temperatures
Effective foam control properties Smooth and lasting shift feel and reduced fluid loss in severe service operating conditions
Compatible with all common seal materials used in Type IID transmissions Maintains effective leakage control
Applications
Mobil ATF 220 is recommended for some automatic and manual transmissions in passenger cars and light trucks specifying Dexron IID level performance as well as the related power steering systems. It is also suitable for use in some special hydraulic systems in farm equipment and other installations having similar fluid requirements. It is recommended that the user consult the manufacturer's requirements. Other applications include:
Off-highway transmissions power steering and other hydraulic systems requiring a Dexron IID or Allison C-4 fluid.
Industrial hydraulic systems and components.
Specifications and Approvals
Mobil ATF 220 has the following builder approvals:
MB-Approval 236.7 X
MAN 339 TYPE V-1 X
MAN 339 TYPE Z-1 X
VOITH TURBO H55.633536 (G607) X
ZF TE-ML-04D/11A/14A X
According to ExxonMobil, Mobil ATF 220 is of the following quality level:
GM Dexron II X
Allison C-4 X
Renk Doromat X
Caterpillar TO-2 X
Ford M2C163-A X
GM Type A Suffix A X
Typical Properties
Mobil ATF 220
Viscosity, ASTM D 445
cSt @ 40C 37
cSt @ 100C 7.0
Brookfield Viscosity, ASTM D 5293
-cP @ -40C 33,000
Viscosity Index, ASTM D 2270 153
Pour Point, C, ASTM D 97 -44
Flash Point, C, ASTM D 92 200
Density @15C, kg/l, ASTM D 4052 0.870
Colour Red
Health and Safety
Based on available information, this product is not expected to produce adverse effects on health when used for the intended application and the recommendations provided in the Material Safety Data Sheet (MSDS) are followed. MSDS's are available upon request through your sales contract office, or via the Internet. This product should not be used for purposes other than its intended use. If disposing of used product, take care to protect the environment.
Old 10-04-2013, 02:27 AM   #3 (permalink)
Originally Posted by newsavedone View Post
Greetings!
Mobil ATF 220
Product Description
Applications
MB-Approval 236.7 X
MAN 339 TYPE V-1 X
MAN 339 TYPE Z-1 X
GM Dexron II X
Allison C-4 X
Renk Doromat X
Caterpillar TO-2 X
Ford M2C163-A X
Typical Properties
Mobil ATF 220
cSt @ 40C 37
cSt @ 100C 7.0
-cP @ -40C 33,000
Colour Red
Health and Safety
I already know about Mobil ATF 220 but no information regarding Suzuki ATF 2384K.
Any body who has specification of Suzuki ATF 2384K?
Old 10-04-2013, 06:12 PM   #4 (permalink)
Gallery: 22
Greetings! The problem is most motors on this section of the forum are F6, 3 cylinder gas.
The Carry U have came from Suzuki dealer, and they are the ones to see about your problem. I googled K6 engine, and got a 4 0r 5 cylinder diesel motor for big truck.
Do you have a picture of your motor?
The Suzuki transmission fluid returns no answers when researched.
Try looking for a man named Fordham call sign on this forum. He is in central America I think
Old 10-04-2013, 11:17 PM   #5 (permalink)
greetings! The problem is most motors on this section of the forum are f6, 3 cylinder gas.
The carry u have came from suzuki dealer, and they are the ones to see about your problem. I googled k6 engine, and got a 4 0r 5 cylinder diesel motor for big truck.
The suzuki transmission fluid returns no answers when researched.
Try looking for a man named fordham call sign on this forum. He is in central america i think
I have attached pictures.Any member from Japan this vehicle was imported from Japan, I just need the specification of Suzuki ATF 2384K, tried google but did not find anything.
Click image for larger version
Old 10-06-2013, 03:21 PM   #6 (permalink)
Guest
I get several hits from Google:
https://www.google.co.uk/search?sour....0.wUyX-0-ERDM
Fordem is in the Caribean.
Old 10-07-2013, 01:05 AM   #7 (permalink)
Any member from Japan?
Old 10-07-2013, 02:55 AM   #8 (permalink)
kernelpanic's Avatar
kernelpanic is on a distinguished road
Good day Sir;
Most newer automatics from the late 90's on require a synthetic or synthetic blend ATF
According to this link, yours is a blend. MJ-323. MITASU MULTI VEHICLE ATF Synthetic Blended - MITASU OIL CORPORATION, JAPAN
a dextron 3 or dextron 4 should meet your cars spec.
Bruce
ASE Certified master auto tech of 38yrs
Owner of [URL="http://davaogarage.weebly.com/index.html"]Quantum Mechanics[/URL] of Davao City
77 Mercedes 300D
73 Mercedes 220D
02 Suzuki Carry Van Auto EFI
11 Suzuki Thunder
02 Nissan Terrano Auto 2700 turbo 4X4
"Courage is being scared to death, but saddling up anyway"
-John Wayne
kernelpanic is offline   Reply With Quote Quick reply to this message
Old 10-07-2013, 07:43 AM   #9 (permalink)
Originally Posted by kernelpanic View Post
Good day Sir;
So i put a DExtrpn IID, Which is old, So i need to flush the oil or Dextron IID is also ok?
Old 10-07-2013, 08:49 AM   #10 (permalink)
Sir;
I assume you only added a small amount as a top-off to your transmission. Less than .5 L or so.
If this is correct, no worries. I do believe your system uses a blend of regular dextron II and synthetic in other words a -PARA-SYNTHETIC.
By adding dextron II you may have thinned out the mix by a small %. Small enough it may not cause any issues. total system holds aprox 12 L of ATF.
Being your trans is a 3 speed and not a OD or 4 speed with OD or a lock-up system ..those systems are far more sensitive to there oils than a standard 3 speed.
I would not worry about it much. IMHO
Bruce
77 Mercedes 300D
73 Mercedes 220D
11 Suzuki Thunder
-John Wayne
