acu cooler knob re-activation (original set) - Suzuki Forums: Suzuki Forum Site
Old 07-30-2013, 08:50 AM   #1 (permalink)
redhawk is on a distinguished road
Default acu cooler knob re-activation (original set)
INFO TO THOSE WHO INSTALLED ACU ON CARRY PICKUPS F6A USING ITS ORIG PARTS AND WIRINGS:
The cooler sliding knob at ACU panel (Blue-red strip, Blue for cool (left) and Red for hot (right) could be activated if you can get the original wired switch for it... Its only a very small kit with three wires, one red-white and 2 blue...
The function of it is to control the trigger of the thermostat like new cars... Meaning, a timer control for the compressor depending if the cooling level already reached when set....
Those ac installers have shorted the linewires (2-light blue) going to this switch, so you will notice, your compressor always run all the time and did not come off even the cold level already reached, adding much strain to the engine when the ACU is activated....
Im curious before on what's the use of the small socket in the ACU wire harness and in view of it, i ask my friend importer where he told me that it is connected to said knob....My ACU control panel dont have that switch and I just got it (a very small kit) for free from my friend importer/assembler where i bought my units... I just have it installed yesterday... NO new wiring needed.. I just plug it to where it should be connected to the harness, the small male-terminal socket wired 2-blues..
For info, my ACU wire harness going to ACU control box, compressor, and condenser fan are all original with no cut joints for add-ons, so sockets and condenser-fan relay are still complete...The entire system Works perfect as original.... When the slide knob is set to any mark in cooling position, the compressor triggers off when the corresponding cooling temperature is reached, and vice versa...
I will post the picture of said kit after i will remove the dashboard this saturday for some fixings to my underdash harnesses.....
My next program to discover and activate/install on the ACU system is the second thermo-control sensor on the engine where its function, as my friend told me, is to cut off the compressor once the engine overheats when ACU is ON (an engine protection)....My wire harness has two thermo-sensor wires and two idle-up lines...Usual F6 engines, particularly for those trucks with heaters but no aircon has one thermo-sensor installed with the other outlet just plugged with bolt... Im told that the carry-truck with a factory installed ACU has two sensors already so Im waiting at this time for the item to be available once their imports arrived in their yard...
Hope this info will help to those who want to have the system restored to original... just give much patience and time as removal of the wirings , tapes, instrument meter cluster, and dashboard is required... for info, the acu harness of this baby is a separate system to the other wirelines.... so other wire system is not affected once you remove the acu harness..
THE ABOVE IS A DIY....
thanks
redhawk is offline   Reply With Quote Quick reply to this message
Old 07-30-2013, 09:23 AM   #2 (permalink)
newsavedone's Avatar
Gallery: 22
Greetings! "GUMP" You be a F__king Genius! To quot Gunny Thanks for this post .
Please continue as You appear to be an intelligent man in the mildest of a pack of fools.
Old 07-30-2013, 09:33 AM   #3 (permalink)
thanks sir and all those friends helping... i just have the baby restored to what it is made and designed by the japanese and further make it tough-roadworth to avoid problems during use, knowing problems will cost substantial time, effort, and money, particularly for those (like us) who have no large budget to buy brand-new cars/suv's...
As info, my baby is now on its third year with no problems from the start as i restored it to almost 100% original using all available original surplus items and further enhance aesthetics and undercarriage items which i designed to cater manila-road and uneven terrain conditions..
This forum is of much help to all who need definite/concise information from experiences ,,, To quote and thru this forum, we fruitfully met here in manila with AANANTES (another forum member and now with regular communication) same of which had seen my baby, which is molded from scratch to a presentable, dependable, and tough icon on least cost,...
restoring and enhancing this baby is a nice and productive pasttime and hope owners would love theirs....
ty
Old 07-30-2013, 11:14 PM   #4 (permalink)
kamote09 is on a distinguished road
I guess my AC guy didn't have the time to bring this back to orignal. Anway, they have installed a rotary type thermostat and set to the minimum level. On top of this, I installed a cut-off switch to the compressor and condenser fan. With this functionality, I can turn off my Compressor while leaving the louver fans on...I usually use this when driving during the rain where it becomes to cold and triggers condensation outside the vehicle.
I'll look forward to you the pics so I can check local shops in pampanga...I might give this a shot...thanks as always...keep them coming...
OT - I checked for converting my 4speed to 5 speed tranny and it will cost me around 12k including the cables...i'm still looking for cheaper parts...this might be a bolt on process which I can do myself.
kamote09 is offline   Reply With Quote Quick reply to this message
Old 07-31-2013, 02:08 AM   #5 (permalink)
Its really the thing sir.... ac guys just do it on what they want to make it run and they do not think anymore on how to restore it to orig....
anyway, thanks bro... i will update this coming days...
BTW --- try to canvass bro... 4wd - 5speed transmission only cost around 4k. I just have recently as a spare.... i have here a friend shop selling zuk parts (surplus or bnew)... a certain customer just brought last month the 5s-4wd trans at a cost of 4k on said shop... i think i told you about this shop before..
Old 07-31-2013, 06:16 AM   #6 (permalink)
Thanks for the feedback...i'll visit the shop once I have the time...
