suzuki carry resistor value - Suzuki Forums: Suzuki Forum Site
Old 05-22-2013, 06:45 PM   #1 (permalink)
llaverosv is on a distinguished road
Default suzuki carry resistor value
hi
please need help to find correct resistor value from an a Suzuki Carry 2002 ecu board:
ECU : DG2
G13B MT E24
33920 -76A1
076A1
ECU was burned , already change device MP4304,but there is a resistor also burned R662, that was carboned and its value was not visible.
somebody have a pic of this ECU board, son can see the resistor value ?
or have the right value of this resistor
also it would be so appreciated if can get wiring diagram from this vehicle
without this resistor vehicle have acceleration problems
thanks for help
suzuki carry resistor value-ecu-board.jpg   suzuki carry resistor value-mp4304-replaced.jpg   suzuki carry resistor value-resistor-burned.jpg
llaverosv is offline   Reply With Quote Quick reply to this message
Old 05-23-2013, 03:09 AM   #2 (permalink)
newsavedone's Avatar
Gallery: 22
greetings! Please post a picture of the burned resistor. I can try different views in paint, and sometimes recover what color was on the bands.
Old 05-23-2013, 10:49 AM   #3 (permalink)
Default resistor burned...
hi
when tried to desolder resistor broken since it was completely burned (black);
before to desolder inspect it and didnt see any colour strip, its remains color ( light blue) seems to be a precision resistor .
thanks for help
Old 05-24-2013, 01:56 PM   #4 (permalink)
Default resistor value..
I gonna solder a 200 ohm resistor and let you know if it worked.
but now have another question for the same Van.
not sure how to bench tes a temperature sensor since it has 3 wires instead 2.
can somebody explain hot to test it since it has 3 wires.
thanks
suzuki carry resistor value-sensor1.jpg   suzuki carry resistor value-sensor2.jpg
Old 05-24-2013, 03:20 PM   #5 (permalink)
Guest
I don't have an ECU that looks like that one, do you know what circuit that is part of?
The temperature sensor is a combined unit, one sensor for the ECU and one for the gauge, there is a common ground.
Old 05-24-2013, 03:20 PM   #6 (permalink)
Most likely dual sensors in one unit - one sensor drives the gauge, the other drives the ECU.
Use an ohm meter to check for continuity between the pins, I expect you'll find continuity between all three but one pin will show a similar reading to both of the other two - lets call then 1,2 & 3 starting from left - say 1~2 is 50ohms, 1~3 is 100 ohms and 2~3 is 50 ohms - that would make 2 the common pin - from there just check both sensors as you would a single sensor.
Old 05-24-2013, 06:21 PM   #7 (permalink)
Default ECT sensor
got some info about suzuki Carry.
made measurements =
lt grn/wht and Blu/yellow = 1.5K ohm
yellow/ wht = 504 ohm
still dont know if values are ok
please see attachment
Thanks for help
Old 05-25-2013, 05:13 AM   #8 (permalink)
Guest
I posted a link to the service manual in reply to your post on digital-kaos, the resistance values should be in there.
