2000 DB52T 4x4 not engaging. Help Appreciated. - Suzuki Forums: Suzuki Forum Site
Old 12-23-2018, 12:24 PM   #1 (permalink)
BcCoast is on a distinguished road
Default 2000 DB52T 4x4 not engaging. Help Appreciated.
Hello All,
I am a new owner of a 2000 Suzuki Carry DB52T with 7000 kms on it, and i am finding a few issues.
1. Shifting the transfer case into 4wd does not engage the axle lock but the transfer case is driving the front driveshaft.
2. there is no 4wd light on dash when in 4wd
3. It looks like an electrical actuator on the front diff not vacuum like a lot of posts are talking about
4. it might not be relevant but there is a switch below the shifter i do not know what it is for. it toggles side to side but release to center. i will attach an image of this.
Thanks for now.
I will post another thread regarding a couple other interesting issues with this build.
BcCoast is offline   Reply With Quote Quick reply to this message
Old 12-29-2018, 10:50 AM   #2 (permalink)
Default Problem #1 Solved
Hi there,
For anyone interested the accessories in the cab were a remote wireless winch kit but i did not get the remote or winch so i removed it. ( I have a Warn 4500 with remote kit on order)
The 4x4 actuator is an electric actuator which was seized from sitting to long.
(7000kms on a 2000 model go figure)
I removed the actuator on the front diff (3 bolts and the plug) , took the actuator apart and cleaned , regreased with di-electric, and manually spun the electric motor by hand with wd40 until it loosened up.
then bench tested with 12 volts.
re-assemled, installed and walla!.
4x4 engaging perfesctly and the indicator lamp on dash lights up.
I will make a note to anyone else attempting this. Make sure you install the actuator fully engaged or fully disengaged and the diff is in the same position fully engaged or fully disengaged or else the gear will want to run past the position that it can go or it will not be fully engaged or disengaged on the other end of the rotation.
Old 12-29-2018, 12:08 PM   #3 (permalink)
Darrell.'s Avatar
Thanks for the update, I'm sorry nobody helped (me included) as the seems to be so many variations on the Carry and so little literature available I never seem to know quite what were dealing with.
2005 Grand Vitara MT 1600se.
Old 12-29-2018, 12:17 PM   #4 (permalink)
Darrell.'s Avatar
Is that this jobbie, never even knew about it. Learn something new every day here
Free axle control ?? Suzuki Carry DB52T ????????
Old 12-29-2018, 12:36 PM   #5 (permalink)
Darrell.'s Avatar
Well I went to investigate and there it is, luckly it's screwed together so can be maintained as BcCoast descibed
Old 12-29-2018, 12:38 PM   #6 (permalink)
Darrell.'s Avatar
More pics............
Old 12-30-2018, 10:27 AM   #7 (permalink)
Yes that is the actuator I was referring to.
$303 USD to replace new.
