Hi all, i have a recurring problem with my Suzuki Carry. this one is EFI and Turbo. the problem is it would die after about a 20 minute ride and it gets worse as days pass by using it. the mechanic open the engine and saw water in it and have it leaked test and put it back thinking it was the problem. after a week the issue starts again. below is what we have done so far - Replaced the sensor inside the distributor. fixed timing. replaced ignition coil(twice).overhauled the engine. Check the fuel pressure and replaced the fuel pressure regulator. i may have missed some things but those are the major things that we have done.
Have you tried replacing camshaft sensor sir? i have heard few issues experienced by some of same problem although it was all **62W model. Their solution was replacing the camshaft sensor... Try mentioning these to your mechanic... Try also to join and inquire from this group: https://www.facebook.com/groups/565885806863098/. Lot of people on this site are helpful... hope this help sir...
Related Threads
Suzuki Forums
604.8K posts
126.3K members
Since 2004
