engine dies in rain - Suzuki Forums: Suzuki Forum Site
Old 03-23-2008, 03:07 AM   #1 (permalink)
adba.asb is on a distinguished road
Default engine dies in rain
hello there!
i have this problem. maybe you can share your opinions on why this occurs.
everytime i drive my carry when it's raining, the engine suddenly dies. this will happen either the vehicle is in idle state or moving. if i restart it, the engine would turn on. after a few kilometers, the engine dies again. i already had the carburetor checked and cleaned.
what seems to be the problem?
before the engine dies and when i step on the accelerator to give it more power, it feels like i'm applying brakes.
pls help. thanks!
adba.asb is offline   Reply With Quote Quick reply to this message
Old 04-11-2008, 09:59 PM   #2 (permalink)
Mike Williams is on a distinguished road
Sounds like a short in the fuel pump or you have moister in the fuse box area. Cant be a mechanical issue. Hook up an in-line fuel presure gage and drive it in the rain, see if the pressure drops. Moister in the fuel tank will also destroy a fuel pump. See if your filter has moister in it.
Mike Williams is offline   Reply With Quote Quick reply to this message
Old 04-14-2008, 12:53 AM   #3 (permalink)
thanks for the reply!
Old 04-17-2008, 07:41 AM   #4 (permalink)
WILDCAT is on a distinguished road
Originally Posted by adba.asb View Post
hello there!
pls help. thanks!
Bro,
It's a common problem to most of the mini-truck/van-type/passenger
vehicle. When your high tension wire get wet, there is a possibilty that
the current that flows from the distrbutor to spark plug shorts to ground
shuting off the engine. Or the spark plug contacts get wet so it is very
difficult for it to spark.
Hope it helps.
WILDCAT is offline   Reply With Quote Quick reply to this message
Old 06-04-2008, 01:10 AM   #5 (permalink)
thanks for the replies!
solved the problem. replaced the fuel pump because its not working properly. it will just stop working on its own.
Old 06-04-2008, 09:38 AM   #6 (permalink)
zaviatorz is on a distinguished road
hi friend
yup maybe in ur fuel pump since it is an electronic type it is prone to short circuit try to check if the pump is too hot when ur engine dies then it must have a clicking sound when ur turn ur key to ON mode.also try to check the wires from ur delco which is connected to ur spark plugs,there is a possibility that it got wet disabling ur sparkplugs to function.
zaviatorz is offline   Reply With Quote Quick reply to this message
Old 06-10-2008, 09:56 PM   #7 (permalink)
thank you very much for the reply!
Old 06-11-2008, 05:18 AM   #8 (permalink)
ur very much welcome=)
