1999 every Auto model Engine Vibration with AC on - Suzuki Forums: Suzuki Forum Site
Old 02-01-2008, 12:48 AM   #1 (permalink)
chaminda30 is on a distinguished road
Default DA52V Auto model Vibration with AC on
Hi All
I have a problem with my mini every, when I switch on the AC and break on D or R position in gear box Engine start to vibrate. This is not coming all times probably this happens when engine is get heated. Can somone help me to solve this.
chaminda30 is offline   Reply With Quote Quick reply to this message
Old 02-19-2008, 07:00 PM   #2 (permalink)
ZukiDelight is on a distinguished road
Sounds like your AC idle is set too low. Is your every van CARB or Fuel injected? If its Fuel injected there is a small black plastic knob which has a hose connected to your throttle body. I have a rear mounted fuel injected engine. The adjustment knob on my van is located on the right side corner nearest to the bumper. i set my idle to about 1100 rpm.
ZukiDelight is offline   Reply With Quote Quick reply to this message
Old 02-21-2008, 08:03 PM   #3 (permalink)
Thumbs up Thanks
But this comes in some cases only, do not come every time.
Old 02-21-2008, 10:50 PM   #4 (permalink)
when your engine does vibrate, what is your RPM, also when it starts to vibrate does the engine rev up normally when you press the gas? Could be that your throttle body could be dirty or the vacuum line from the adjustment knob could be dirty. Either that or the adjustment knob itself is bad. This is connected to your AC switch. When you turn your AC on it opens the valve. The knob allows air from your manifold to pull the throttle body to a higher rpm. If it is turning bad than it will work sometimes and other times not. but eventually it will stop working all together. I had the same problem as well. at times my rpm would suddenly drop with A/C. But for me I just cleaned the lines and throttle body and haven't had a problem since.
Old 02-21-2008, 11:06 PM   #5 (permalink)
Thumbs up
Thanks your quick reply dear, I will try and will reply u.
Old 02-25-2008, 01:46 AM   #6 (permalink)
It has NO rpm Meter that is the problem, Anyway I will try to check
Old 03-10-2008, 04:28 AM   #7 (permalink)
I has NO rpm Meter that is the problem, Anyway I will try to check
Dear Sir,
Can you expain something with these photos
1999 every Auto model Engine Vibration with AC on-dsc00803.jpg   1999 every Auto model Engine Vibration with AC on-dsc00797.jpg   1999 every Auto model Engine Vibration with AC on-dsc00794.jpg   1999 every Auto model Engine Vibration with AC on-dsc00796.jpg
Old 03-10-2008, 04:33 AM   #8 (permalink)
Dear Sir,
Can you explain something with these photos
Old 08-17-2017, 04:26 AM   #9 (permalink)
ricoroy11@gmail.com is on a distinguished road
Dear Sir,
i also have the same problem.. my car was fine.. til i have change my oil and my atf...same day i change oil and atf it was still fine.. the following day the engine is now vibrating.. any one who have experience this... can you help... thank you.
ricoroy11@gmail.com is offline   Reply With Quote Quick reply to this message
