F6A No Power - Suzuki Forums: Suzuki Forum Site
Old 12-05-2016, 09:22 AM   #1 (permalink)
AguillardR is on a distinguished road
Default F6A No Power
Engine is hard to start, but idles great. It smothers down when I try to accelerate. When it warms up, it does better, but still not right. Changed the coil, spark plugs and ignition wires. Helped some. What am I missing? Put an aftermarket carburetor with a manual choke on it several months ago.
AguillardR is offline   Reply With Quote Quick reply to this message
Old 12-05-2016, 04:41 PM   #2 (permalink)
aquanaut20's Avatar
Compression # please!
... Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 12-06-2016, 12:28 AM   #3 (permalink)
newsavedone's Avatar
Gallery: 22
Have not worked on a carb in 12+ years, but, does it have a vacuum advance? and is the hose OK?
Old 12-06-2016, 09:38 AM   #4 (permalink)
Thanks, will check hose. How can you tell if vacuum advance is not working?
Old 12-06-2016, 09:40 AM   #5 (permalink)
Thanks, will try to borrow a compression gauge. This is on a 1991 Suzuki Carry with F6A engine. Don't know what compression should be
Old 12-07-2016, 04:27 AM   #6 (permalink)
Gallery: 22
As I remember it, the car will not accelerate. When you pull the hose off, something on the distributor will move.
Old 12-23-2016, 04:45 AM   #7 (permalink)
saltednutz2 is on a distinguished road
compression should be between 140-170 PSI all within 10 percent.
Take the cap off the distributor put a hose on the diaphram can and suck on it if the pickup moves its ok, also check the hose for vaccum when you rev the engine...should help cross off a few possibles
saltednutz2 is offline   Reply With Quote Quick reply to this message
Old 12-23-2016, 04:53 AM   #8 (permalink)
If that dont fix it ...fit a new fuel filter and then start it up let it warm up a bit then remove the intake hose.....then rev it up and place your hand over the intake till it starts to die, do this 2-3 times....your carb could have some crap in it but this trick usually works
