Is the transfer case independent of the transmission? - Suzuki Forums: Suzuki Forum Site
Old 11-11-2016, 10:56 PM   #1 (permalink)
Jerminator96 is on a distinguished road
Default Is the transfer case independent of the transmission?
Hola and greetings from Guatemala!
Can one of you guys help me figure out if the transfer case from a 96 Suzuki Carry van (Every?) is an independent unit, integrated into the manual transmission, or relying on the transmission to form an oil seal?
I found a good deal on one for a project, but I'm not planning on using the motor or transmission, just the transfer case and front/rear diffs. Also, what's the suspension like on these? Leaf and solid axles front and rear?
I would like to know this stuff before I go check out the car. It's not too far away, but it's also in one of the most dangerous cities in Guatemala, so I'd rather not go there if it'll be a waste of time.
Thanks all.
Jerminator96 is offline   Reply With Quote Quick reply to this message
Old 11-12-2016, 04:54 AM   #2 (permalink)
Darrell.'s Avatar
Welcome to the forum. From what I can find the 4wd transferbox bolts directly onto the transmission so is not independent. Sounds like you could do with an old Samurai transferbox .
2005 Grand Vitara MT 1600se.
Old 11-12-2016, 05:03 PM   #3 (permalink)
Bummer, I was hoping to use the existing setup and drive the transfer case via drive shaft from a liter bike engine output shaft.
I might just have to go back to my original plan and use a standard RWD carry van. I'm stripping the body off the chassis to build an off-road buggy, so I was pretty happy to find they came in 4wd.
Old 11-12-2016, 05:15 PM   #4 (permalink)
Though, I suppose I could run an adapter to the transmission input shaft instead...
I'd end up with 30 gear ratios to choose from, and 6 reverses.
