shaky engine - Suzuki Forums: Suzuki Forum Site
Old 09-21-2007, 06:56 AM   #1 (permalink)
adba.asb is on a distinguished road
Default shaky engine
hello guys! i'm new here.
i have a problem with my suzuki carry ride.
maybe you can give me some diagnosis on what's my problem.
every time im idling, my engine shakes and when i turn on my a/c even more shakes occur. also when i rev up the engine, stronger shakes will appear. if i also engage in first gear and starts to run, shakes also would occur.
what do you think is the problem?
i encountered this similar type of problem a few months ago and got it repaired. i replaced the spark plugs and the black cables connected to it. but the problem appeared again.
i don't know what to do. thanks in advance!
adba.asb is offline   Reply With Quote Quick reply to this message
Old 09-25-2007, 02:13 AM   #2 (permalink)
pascalhatesworm
3 things you may need to check:
1. point gap (if your engine is with a distributor)
2. high tension cables - make sure none is loose both on spark plug ends and distributor end. replace if worn.
3. Proper carb fuel/air mixture.
pascalhatesworm is offline   Reply With Quote Quick reply to this message
Old 10-01-2007, 04:11 AM   #3 (permalink)
Smile
thank you guys for the replies!
got it fixed. i just had the spark plugs cleaned up. some carbon deposits have formed causing those shakes i felt.
Old 05-29-2008, 06:53 AM   #4 (permalink)
newsavedone's Avatar
Gallery: 22
Default Shaky engion
Greetings! WHY is carbon foweling your plugs so quick? How long since you changed the air filter?
Is the carb running rich? Just curious
