F6A DB51T Vacuum Diagram? - Suzuki Forums: Suzuki Forum Site
Old 03-01-2016, 11:24 AM   #1 (permalink)
sigk is on a distinguished road
Default F6A DB51T Vacuum Diagram?
Hi guys, I live in the USA & just became a 'New' member needing some 'Expert' help.
Have completed a full engine rebuild / overhaul for 1991 Suzuki Carry DB51T, & am needing a correct Vacuum hose line & check valve location (+ flow direction) routing diagram.
Vacuum data:
Carb Flange: 4 ports
Intake manifold: 2 ports
Devices: Dist. 1 port + EGR 1 port + 1st. Carb Throttle Vac. Servo 1 port + 2nd. Carb Throttle Vac. Servo 1 port + Choke Vac. Servo 2 ports + Coolant Thermal Switch 2 ports + Air Cleaner Gate Valve 2 ports.
Appreciate your very kind help very much, please post or send actual Pics. or, PDF or Vacuum line connect / routing layout.
Many thanks!
Sig
sigk is offline   Reply With Quote Quick reply to this message
Old 03-01-2016, 04:47 PM   #2 (permalink)
Darrell.'s Avatar
I seen to remember this being asked a few times in the past, but don't remember seeing good diagrams. The hose layout seems to vary a lot and is a complicated set up.
Hope this may get you started at least Emission control ?? Suzuki Carry DB51T ????????????
2005 Grand Vitara MT 1600se.
Old 03-01-2016, 06:09 PM   #3 (permalink)
newsavedone's Avatar
Gallery: 22
Greetings! I have posted several pictures, and drawings about these lines on this forum.
Do a search here first.
