new distributor - Suzuki Forums: Suzuki Forum Site
Old 03-02-2007, 05:27 PM   #1 (permalink)
isporttrak is on a distinguished road
Question new distributor
hi guys,
am planning to change my distributor from the current mitsubishi (hi-cap with a mechanical fuel pump attached to the housing) with a nippon denso (low-cap distributor but without a mechanical fuel pump built into the housing). i need to know if the helical gears match and if the length of the distributor arm is the same.
before i touch it, does anyone know if it's ok to use the top part of the nippon denso distributor only and use it on the housing with the mechanical fuel pump on it? this way i dont have to install en electric fuel pump assembly.
also, can anyone say which is better for our carry rides, a mechanical fuel pump or an electric one.
thanks for the info.
isporttrak is offline   Reply With Quote Quick reply to this message
Old 03-03-2007, 08:58 PM   #2 (permalink)
mang_caloy
My pickups came with electric fuel pumps as standard issue. Not too sure about the distributors though. I have a spare distributor lying around if you want to check it out. It still has contact points and a condenser though.
mang_caloy is offline   Reply With Quote Quick reply to this message
Old 03-04-2007, 05:51 AM   #3 (permalink)
thanks mang caloy but i have both types. i just dont want to touch it without a second opinion. but does using an electric fuel pump better than having a mechanical one? or is it the other way around?
Old 03-09-2007, 01:53 AM   #4 (permalink)
mang_caloy
I usually use stock pumps for generally stock engines. Unless you've significantly changed your carbs or injectors, I don't see the need for changing your fuel pump.
Old 03-10-2007, 09:01 PM   #5 (permalink)
thanks for the info. no major change.
