advise on my carry... - Suzuki Forums: Suzuki Forum Site
Old 02-20-2007, 07:55 PM   #1 (permalink)
gnm593 is on a distinguished road
Default advise on my carry...
advise from our knowledgeable master here for our carry.just ask your off topic questions here.
let me start.
::my carry is seldom used for 1 week, i will only use it twice or sometimes hindi talaga for straight five days,coz dito sa cebu grabe ang trapik in the morning and evening, lalo na sa route ko going to work. maaksaya sa gas at nakakapagod sa pag drive, but i will see to it na every morning i turn up the engine for five minutes.now, hindi ba masisira yung engine or what?
advise guys...thanks in advance.
gnm593 is offline   Reply With Quote Quick reply to this message
Old 02-20-2007, 10:00 PM   #2 (permalink)
BRUCE LI's Avatar
Gallery: 3
BRUCE LI is on a distinguished road
I'm not a "master" bai, but i'll share my ideas. . .
Before, I also used my ride once or twice a week (nagtitipid din sa
gasolina) 'coz we have our company service bus also, "hatid-sundo"
from house to office. I make it a point to turn ON the engine every
morning for at least 5min just to take out the moisture from the oil
& to lubricate the pistons & other parts as well so they won't rust
easily. But now I'm using it 4 to 5 times a week, so ok lang if I won't
turn it ON for 5min in the morning.
I've read from one forum that if you won't use it for a long time, say
more than one month, you should disconnect the battery 'coz it will
drain consequently, "lalo na sa set-up nating mga Carry/Every" that
our horn, headlights, hazard, brake lights can function w/o the key.
In my opinion, they can affect the discharging of the battery even
when the engine is OFF. Maybe because of the "voltage drop"
thing (i'm not sure).
They say that busted oil seals & oil leaks are some common problems
encountered by owners who don't use their vehicles for a long time.
Well, I don't know if they're true. Haven't experienced it yet, hehe. . .
Any more advise???
DRIVE SAFELY & BE COOL !!!
BRUCE LI is offline   Reply With Quote Quick reply to this message
Old 02-20-2007, 11:12 PM   #3 (permalink)
@bruce:thanks for the input bai,highly appreciated. btw,i don't use my ride regularly coz hindi na oil change,last change ko was march last year.can that also cause damage to the engine? i also found an oil dropping on my zuki after i ON the engine one morning but lately wala na.could that be busted seals? how can it be busted when i don't regularly use my zuki?
Old 02-21-2007, 02:36 AM   #4 (permalink)
BRUCE LI's Avatar
Gallery: 3
Same here, leaking oil but I replaced the oil seal, don't know if it's
already there when I bought it or it's the result of not using it for
some time. Anyway, I can't explain how the seals can be busted,
I'll try to look for that article (previously saved in Word file) & will
try to post it here tomorrow.
See yah.
Old 02-21-2007, 02:41 AM   #5 (permalink)
ok bruce, looking forward on it.
Old 02-21-2007, 05:29 PM   #6 (permalink)
blue is on a distinguished road
i agree with BRUCE LI. whenever you're going out for more than a week, make sure you remove the battery, or probably just the negative terminal...
blue is offline   Reply With Quote Quick reply to this message
Old 02-21-2007, 09:37 PM   #7 (permalink)
j-six is on a distinguished road
i agree. disconnect the battery from the terminal if and only if you will not use it for a month or more. pero if you start it up even once a week the alternator will charge the battery so no problem. but if you'll not use your carry for more than a month then try disconnecting the battery.
we use more frequently the apv than our carry so we do not disconnect the battery, even if we use our carry for only once a week. my 2 cents.
j-six is offline   Reply With Quote Quick reply to this message
Old 02-21-2007, 10:51 PM   #8 (permalink)
Yellowturtle
Hi guys!
In my experience with my 1976 L-type Lancer when I rarely used it for a month and just warm it up for 5 minutes that it makes the rubber, oil seal and the brake pads fragile.
I brought out my car for a short drive after a month of not using it and I was travellng down on an incline road. Lightly depressing my brakes when all of a sudden a loud metallic noise was heard and at the same time I've felt a strong jerking motion making my car stop in the middle of the road. My rear brakes had locked and I was not able to drive it. I was lucky that there were no vehicles behind me and I was near a friend's autoshop that I could wake-up early in the morning.
He told me that it was unwise to stock your car and just warm it up every morning. It should have been warm-up and driven in a short distance to avoid mechanical break down due to prolonged unused. (Instead of being able to save I have to spend for the unnecessary repairs that is avoidable)
If your not going to use your car for quite sometime beside warming-up the engine, you should drive it around the neighborhood. It will warm-up not only the engine but the rest of your cars mechanical parts like the brake system, the oil in the differential and of course charging your battery as well.
Hope this helps.
Yellowturtle is offline   Reply With Quote Quick reply to this message
Old 02-22-2007, 12:10 AM   #9 (permalink)
thanks yt for the input. when my zuki is standby, i won't use the hand brake, that's the suggetion of my mechanic. i just use stone's instead.
Old 02-22-2007, 01:55 AM   #10 (permalink)
BRUCE LI's Avatar
Gallery: 3
Any explanation why the hand brakes shouldn't be engaged???
Anyone???
