Change Gear - Suzuki Forums: Suzuki Forum Site
Old 02-20-2007, 02:40 AM   #1 (permalink)
BRUCE LI's Avatar
Gallery: 3
BRUCE LI is on a distinguished road
Question Change Gear
Guys, what RPM do you usually upshift from a lower gear?
In a freeway (no traffic), how many seconds do you have to stay in one
gear before you can reach the 5th gear? (normal driving)
What is the minimum RPM that you can shift to 5th gear?
Thanks in advance.
DRIVE SAFELY & BE COOL !!!
BRUCE LI is offline   Reply With Quote Quick reply to this message
Old 02-20-2007, 04:59 AM   #2 (permalink)
j-six is on a distinguished road
as for me it takes about 1 minute on free highway w/o traffic, smooth gear shifting. pero if you try to almost redline it before shifting syempre mga about 30 seconds.
nga pala, my super carry doesn't have a redline (tachometer) kaya i shift via engine sound.
j-six is offline   Reply With Quote Quick reply to this message
Old 02-20-2007, 03:38 PM   #3 (permalink)
blue is on a distinguished road
ako rin, walang tacho... so i base it through engine sound... i'm planning to add a tacho soon, its around Php 800, lang naman for 3inch tacho...
blue is offline   Reply With Quote Quick reply to this message
Old 02-20-2007, 07:30 PM   #4 (permalink)
gnm593 is on a distinguished road
bro,can you tell me where can i buy the tacho? and where,who can install this?
coz, meron akong nakita dito Php2,500 ang benta nya.
btw, sometimes i over rev on my 1st gear to second gear shifting.thats why i really need to install this thing
gnm593 is offline   Reply With Quote Quick reply to this message
Old 02-20-2007, 08:40 PM   #5 (permalink)
BRUCE LI's Avatar
Gallery: 3
bro j-six, you mean from say 2nd gear to 3rd gear you waited for 1min.
to upshift? or you mean the whole 1 minute from 1st gear to 5th gear??
Anyway during heavy traffic you can stay in say 2nd / 3rd gear for
a few minutes as long as you don't really push hard on your gas.
Exception of course if you go to Baguio or any mountain road uphill
in which staying in 1 gear (1st / 2nd gear) is inevitable.
Actually I asked all your ideas to check if I'm doing the right thing with
my shift stick. In my case, I do this: (on plain, no traffic road)
1st - 2nd: max. of 2sec. only
2nd - 3rd: abt. 3sec. or 2500rpm (whichever comes first)
(actually on a plain road, I often start with 2nd gear from a halt)
3rd - 4th: abt. 5 - 6sec. or 3000rpm (whichever comes first)
(longer 'coz I like the sound of my engine on 3rd gear compared to 4th, etc., it's like a sports car, hehe. . . but no muffler)
4th - 5th: at least 6sec. or 2500rpm (whichever comes first)
Old 02-21-2007, 07:03 AM   #6 (permalink)
isporttrak is on a distinguished road
my speedo has the gear numbers on it (2nd gear on 20khp, 3rd gear on 40kph, 4th gear on 60kph) so ideally you shift on these speeds (mine is a four speed only). but i rely more on my tachometer for changing gears. on relaxed days i shift at 4000 to 4500rpm but on days when i feel the need for speed i shift at 5000 to 5500rpm to maximize each gear. but of course all of this is taxing on the engine (see my other post on overheating!).
enjoy shifting!
isporttrak is offline   Reply With Quote Quick reply to this message
Old 02-22-2007, 02:17 AM   #7 (permalink)
BRUCE LI's Avatar
Gallery: 3
enjoy shifting!
We have a slightly different RPM values for shifting gears. If I tried
yours maybe I'll be the king of the streets, hehehe. . . overtaking
every vehicle on the road. Anyway, maybe we have different settings.
Just one question: What's your idle RPM ???
Mine is slightly over than the Specs. (1,200 rpm)
Specs written on my engine hood / cover is 900+-50 rpm.
Old 02-22-2007, 05:04 AM   #8 (permalink)
hi bruce,
let me rephrase my previous reply...
i only have 4 forward gears so a 5speed gearbox would perform differently. the numbers on my speedo (which reads only up to 100kph) are 1 at 20kph, 2 at 40kph, 3 at 60kph. so this means i can use 1st gear up to a speed of 20kph, 2nd gear up to 40kph, 3rd gear up to 60kph, then 4th gear upwards. this is the ideal situation.
normally i just use the 1st gear to get the truck rolling then quickly shift to 2nd gear up to about 20kph then shift to 3rd until 60kph then 4th gear from here. that's because i rely on my tach. the figures on the speedo are just a guide since there is no OEM tachometer.
my idiling right now is at 950rpm. when the engine is hot it plays up to 1000rpm but more or less stabilizes at 950rpm.
hope this helps.
Old 02-22-2007, 08:23 AM   #9 (permalink)
bruce, just an add-on...
when i overheated my engine (well not really overheating but very high temp-half the gauge) i was running my idle at 1500rpm. a bit taxing talaga on the engine and forget about fuel efficiency! haha.
i bought a new distributor cover and wire harness so i retuned my idle to 950rpm. old wires and connections tend to play with your rpm because of the inefficient conduction of electricity.
i think your 5speed tranny helps a lot in terms of fuel efficiency as well as your efi. the engine's tick-over is a good indicator of when to shift up. but of course it depends if you're on an incline or carrying heavy loads.
Old 02-22-2007, 09:10 PM   #10 (permalink)
BRUCE LI's Avatar
Gallery: 3
hi bruce,
i only have 4 forward gears so a 5speed gearbox would perform differently. . .
Thanks for for the inputs isporttrack, also read your additional info.
Anyway, just to clarify about your statement above, do you mean
that we have different gear sizes for 4 speed & 5 speed??
Pls. correct me if I misunderstood you, ok?
I didn't have the chance to open my tranny but I believe our gear
ratio is "more or less" similar to these:
Gear Ratio
1st 2.315:1
2nd 1.568:1
3rd 1.195:1
4th 1.000:1
5th 0.915:1
Standard Part
1st 3.584:1
2nd 2.022:1
3rd 1.384:1
4th 1:1 4th
5th 0.861:1
Maybe sir monometalico will have a precise answer for this . . .
Anyone knows our exact gear ratio ????
