speedometer and odometer readings - Suzuki Forums: Suzuki Forum Site
Old 08-31-2006, 05:59 AM   #1 (permalink)
lance_pad's Avatar
lance_pad is on a distinguished road
Exclamation speedometer and odometer readings
I know this may sound insignificant but this may be worth mentioning. a little comment regarding speed measurements on your vans or trucks. If not all, majority of us here have 13" wheels which is one inch larger than the stock 12" wheels. I believe our speedometers and odometers are not giving us correct measurements.
If for example i'm using 175/70R13 tires, that's equivalent to approximately 4.8" section height, multiply that by 2 and add 13" for the wheel diameter, we get 22.6" total diameter of the tire. This translates to 71" tire circumference. This means that for a tire this size, one rotation means traveling 71".
On the other hand, if the speedometer design was based on the stock tire size of 165/60R12 for example, one wheel rotation translates to only 62" traveled linearly. There's a discrepancy of 9" per tire rotation. That's about 15%.
From this data, if our odometer reads 10km, it should have been 11.5km. Consequently, our speedometers might also give us inaccurate readings. For us who base our km/L measurements on the data given by our odometers, we might consider the % difference especially when we are dealing with hundreds of kilometers.
lance_pad is offline   Reply With Quote Quick reply to this message
Old 08-31-2006, 06:04 AM   #2 (permalink)
nils is on a distinguished road
well i've got bigger wheels on my vitara, so the speedometer is slower than stock, about a 10%.
But the speedometer is stock not 100% acurate, and reads more than actual.
Compare your speedometer with a gps and see how much its different with larger tires. Wont be much i can tell you that
nils is offline   Reply With Quote Quick reply to this message
Old 08-31-2006, 08:52 AM   #3 (permalink)
shadownseiko is on a distinguished road
Sorry, you cannot compare your speedometer with a GPS and come up with any kind of an accurate measurement, UNLESS, the road has absolutely no curves whatsoever.
Most highways here have markers. Find one that has markers for 50 or 100 km and drive it, noting the difference between the highway markers and your speedo. With just a small grasp of mathematics, you then know almost exactly the percentage your speedo is off, and then can determine km/ltr accurately.
Larry.
shadownseiko is offline   Reply With Quote Quick reply to this message
Old 09-01-2006, 08:38 AM   #4 (permalink)
pascalhatesworm
Someone correct me if i am wrong. but that does really count? - i mean the tires size? My speedo cable is inserted on the trannny just somewhere near propeller. so tire size wouldnt matter.
I used to have a volks beetle, on this car the cable is at the front wheel on the left - for this i think tire size matters.
pascalhatesworm is offline   Reply With Quote Quick reply to this message
Old 09-01-2006, 11:08 AM   #5 (permalink)
Ok, so your speedo is connected to your tranny, which is connected to your differential, and your differential is connected to your tires. How would it NOT count?
Sorry, I'm at a loss here.
larry.
Old 09-03-2006, 10:04 PM   #6 (permalink)
lance_pad's Avatar
Smile
we can put it this way; if we just assume that the gear ratio between transmission-differential is 1:1. One turn on the tranny would result to a longer linear distance traveled by a bigger tire compared to using a smaller tire. One turn is equal to the circumference of the tire.
As what larry said, we can just note the landmarks on the sides of the road and compare them to the readings on our odometers. From experience, mine varies by about 15% since i am using a taller tire.
Old 09-03-2006, 10:47 PM   #7 (permalink)
mang_caloy
Tire size affects your overall gear ratios.
mang_caloy is offline   Reply With Quote Quick reply to this message
Old 09-06-2006, 09:24 AM   #8 (permalink)
pascalhatesworm
OK. I stand corrected.
Old 09-06-2006, 08:09 PM   #9 (permalink)
lance_pad's Avatar
oops! my odo reading is 20% less than the actual km. just noted it this morning. good for us here in the philippines since highway officers don't have laser speed guns. we might argue that we're just doing 60 but actually we're going 72km/h.
Old 10-01-2007, 06:02 AM   #10 (permalink)
bluesh1 is on a distinguished road
Default ...
if some one like to have an acurate speedo reading try to use a laser sensor speedo like the use in bicycle
bluesh1 is offline   Reply With Quote Quick reply to this message
