Adjusting A/T shifting. - Suzuki Forums: Suzuki Forum Site
Old 11-11-2014, 07:23 AM   #1 (permalink)
gregorymark1 is on a distinguished road
Default Adjusting A/T shifting.
My (1995?) suzuki multi cab with an automatic transmission, doesnt shift like it should. It doesnt shift soon enough. The engine will rev too high before it finally decides to shift into 2nd, causing it to jerk hard. Any ideas on how to fix this?
gregorymark1 is offline   Reply With Quote Quick reply to this message
Old 11-17-2014, 01:42 AM   #2 (permalink)
kernelpanic's Avatar
kernelpanic is on a distinguished road
Several things I would check. That will depend on what system you have.
First quick thing to do is test the TPS making sure you have a constant return wire voltage from closed of aprox .8-1.0 vdc to 5.0vdc (or near) at full open.
Check the "kick down cable" if equipped. That is the cable exiting the trans case near the pan, going up to the throttle. It will be attached near where your throttle cable attaches. They can loosen up and move out of adjustment.
Again, if equipped.. check the VSS. That runs your speedometer and tells the computer how fast you are going, and the computer calculates shift points off of that data. If your speedo happens to acting strange, check this first. I see this often, speedo not working, and trans shifts poorly or not at all. Fix one problem and cure 2 for one :-)
Hope this helps
Bruce
ASE Certified master auto tech of 38yrs
Owner of [URL="http://davaogarage.weebly.com/index.html"]Quantum Mechanics[/URL] of Davao City
77 Mercedes 300D
73 Mercedes 220D
02 Suzuki Carry Van Auto EFI
11 Suzuki Thunder
02 Nissan Terrano Auto 2700 turbo 4X4
"Courage is being scared to death, but saddling up anyway"
-John Wayne
kernelpanic is offline   Reply With Quote Quick reply to this message
