Redhawk revised body lifter kits - Suzuki Forums: Suzuki Forum Site
Old 01-11-2014, 03:52 AM   #1 (permalink)
redhawk is on a distinguished road
Default Redhawk revised body lifter kits
Here are the pics of my revised body lifter from 2 inch to 3 inch using orig shockmounts at the front same as the previous..... Lower hole was done by machine shop.
Rear shackles hole distance = 18 cm with holes done by machine shop following the original bolt diameters..... Stainless-steel hat-type self-locking nuts were used.....
Pipe tube should be skewed a little bit in order that the tires should be in vertical position and that the shock absorbers should be perpendicular to the lower plate of the lift kit....
Pics of Modification of front cross-member and strut connection to lower-arm will follow later on........
redhawk is offline   Reply With Quote Quick reply to this message
Old 01-11-2014, 06:41 AM   #2 (permalink)
Just so you're aware of it - what the pictures show is a suspension lift - not a body lift.
A body lift implies that you have lifted the body from the frame, since a Carry van is unibody (monocoque) construction, it has no separate frame and cannot be "body lifted".
