1994 Suzuki Alto 657cc Problems - Suzuki Forums: Suzuki Forum Site
Old 11-14-2015, 02:36 PM   #1 (permalink)
deadeyedent is on a distinguished road
Default 1994 Suzuki Alto 657cc Problems
Hi everyone,
I'm a new member seeking some advice (tried searching the forum) on my wifes 1994 Suzuki Alto with the 657cc F6a engine. It has a genuine 34,000kms on the clock having been owned by my grandmother since new before we obtained it as a run around car. Here's the story:
On occasion (and usually when cold i.e. 0 degrees or less) the car has stalled when stopped after a short drive. It can idle a bit rough and there is a noticeable change in rpm when the headlights are turned on etc. and will sometimes stall when put into gear especially when the engine is cold.
I have replaced all the spark plugs and ignition leads but the problem still occurs. Yesterday I realised that the alternator belt had a lot of flex or 'slack' in it and it has partly de-laminated. My thoughts are therefore that the slack and worn belt is causing a fluctuation in voltage to the battery and causing the above issues?
I attempted to tighten the belt yesterday as a short term fix before getting it replaced (if that is indeed the likely problem) and to get at the necessary bolt I had to remove the vacuum hose off the brake booster.
I have put it all back together (couldn't make much difference to the belt) but now the brake pedal is very hard and the brakes only work if i put a lot of force on the pedal despite having tried to bleed them through the bleed nipples on each wheel.
So my questions are:
1. Is the worn and slack alternator belt likely to be the cause of the rough idle/stalling under load?
2. how can I get the brakes to work properly again after removing the vacuum hose?
3. does anyone have or know where I can get a decent workshop manual or at least find the correct part numbers for an alternator belt and cam belt kit so I can order these? I cant seem to find any info on the net for this specific make and model of car....
Thanks for taking the time to read this long post and any assistance
deadeyedent is offline   Reply With Quote Quick reply to this message
Old 11-15-2015, 01:24 PM   #2 (permalink)
Guest
A leaking vacuum hose to the servo will cause the brake problems, you need to check carefully for leaks, it will also cause an idle problem.
