Fuse Keeps blowing issue - Suzuki Forums: Suzuki Forum Site
Old 05-10-2015, 11:00 AM   #1 (permalink)
gerry2345 is on a distinguished road
Angry Fuse Keeps blowing issue
Hi Everyone
Everytime I plug either a charger or anything else into the cigarette lighter plug of my Alto SZ4 the fuse blows and the radio stops working.
Does anyone know how to cure this issue or add some workaround so the fuse does not keep blowing.
gerry2345 is offline   Reply With Quote Quick reply to this message
Old 05-10-2015, 02:07 PM   #2 (permalink)
Darrell.'s Avatar
Welcome to the forum. I have no experience with the Alto, but as it blows when you plug in regardless of the load of the appliance, I would assume it's the socket shorting out somehow.
Do you have a multimeter ?
2005 Grand Vitara MT 1600se.
Old 05-10-2015, 03:10 PM   #3 (permalink)
Yes I have a multimeter...
Can you advise how I should connect it and what I need to look out for.
Thanks for reply
Old 05-10-2015, 03:27 PM   #4 (permalink)
Darrell.'s Avatar
Assuming there is a connector on the back, I would disconnect it. Put the multimeter on continuity/ohms across the 2 wires on the back of the socket and use an old plug (I seem to have loads!!) with no wires and plug that into it. The meter reading should not change indicating open circuit.
Has it also got the correct fuse size supplying it.
I assume your not trying to use an appliance that's using more current than the socket is rated for.
Old 05-11-2015, 05:23 PM   #5 (permalink)
OK Thanks.
I will try that.
The appliance is rated at 1w and the fuse indicating on the plug is 15amps.
I dont think it is more than the socket rating.
Old 05-21-2015, 09:54 AM   #6 (permalink)
Hi Dudleydo. I have just tried another charger thats 1000ma in the cigarette lighter and it works ok. Although I have not tried what you suggested yet but I do suspect that the item that I would like to work in the cigarette lighter is somehow changed because it did work initially and now does not work.
Is there anything I can do to the FM transmitter to make it work in the cigarette lighter socket.
