changing reverse bulb - Suzuki Forums: Suzuki Forum Site
Old 03-08-2015, 10:16 AM   #1 (permalink)
CLARKY1955 is on a distinguished road
Default changing reverse bulb
Alto SZ4 2011- UK
handbook shows removing 2 screws from the rear light combination unit but once done, I can't seem to remove the cover? are there more screws to remove, it isn't clear or maybe I am just a muppet.
CLARKY1955 is offline   Reply With Quote Quick reply to this message
Old 03-10-2015, 05:28 PM   #2 (permalink)
colbry is on a distinguished road
This may help if yours is the same
Colb
colbry is offline   Reply With Quote Quick reply to this message
Old 03-20-2015, 05:27 PM   #3 (permalink)
maxlev is on a distinguished road
I`m thinking it is the same as my 4 yr old Vitara, remove visible screws and pull out toward rear which releases the 2 or 3 clips on other side of lense from the screws. My 2 month old Alto has no blown bulbs so have not removed lense yet.
maxlev is offline   Reply With Quote Quick reply to this message
Old 03-21-2015, 12:56 PM   #4 (permalink)
Default Rear light cluster removal
Had a look around a 2010 Alto today and checked the rear light clusters.
To get at the bulbs you need to remove the cluster by removing the two 10mm screws best to do so with a 10mm socket, also remove the centre screw on the bumper panel middle of the boot opening as you need to spring back the panel to release the light cluster. You need to pull the light cluster rearwards when the two screws are removed this releases the two locating pegs that are holding the outer edges of the light cluster. Spring the bumper panel outwards so you can lift the cluster out and in front of the panel, once in front of the panel the cluster should lift out and you can get at the bulbs.
Colb
