2002 Aerio Won't Start - Suzuki Forums: Suzuki Forum Site
Old 07-26-2010, 04:43 PM   #1 (permalink)
Strontium90's Avatar
Strontium90 is on a distinguished road
Default 2002 Aerio Won't Start
There is no MIL, no indication of anything wrong, and everything is working until it will not start. The intermittent behavior does not trip a DTC so I can't read a code to complain about. The engine cranks briskly but will not start. Testing shows the plugs are firing and when I've checked for fuel it was pumping, but then after testing, the engine started. I'm thinking its in the fuel pump system as I replaced the fuel pump at 97,000 miles which was this spring. the ground wire to the fuel tank was badly corroded when I cut if of so I removed about a foot of it and soldered a new section on which was fitted to the tank with a stainless steel fastener and copper anti-seize for added conductivity and prevent corrosion. After that repair it was working fine for the last five months until this intermittent problem has raised its ugly head. After failing to start four times in about three weeks it has now continued to work without incident for the last two weeks. Anybody got any ideas on where to look?
Strontium90 is offline   Reply With Quote Quick reply to this message
Old 09-01-2010, 09:11 PM   #2 (permalink)
ELS
ELS's Avatar
ELS is on a distinguished road
Hello,
I'm not replying necessarily to your problem, BUT I am having the same problem, my 2002 Suzuki Aerio SX, was running last night (Tuesday evening, August 31, 2010.) I drove it home from college (full time student).
I parked it for the night. Got into it this morning (Wednesday, September 1, 2010), it cranks but refused to start.
I had classes today, so took public transportation.
Just quickly asked brother-in-law to use his diagnostic's checker tool, hooked up to my car.
Showed NO CODES AT ALL. Nothing in stored codes or anything.
Dark (nighttime here now, NY), so can't do much in the dark, too late for trouble light work. (No garage).
Tomorrow, Thursday, Sep't. 2nd, I'm starting with (as best I can) with the preliminary checks, spark, fuel, air flow (for combustion.)
However, I am only trained from self mechanics repairs and routine maintenance, on older model vehicles. Ones that had conventional spark plug wires to check for spark, fuel line, will trace, and turn key for electric fuel pump working.?
I have NO repair manual, (book), just got the car used from a friend.
I'm not sure about the spark plug / coil packs (think that they are called)? How to check for spark..?
Any help and idea are appreciated...
As I said, NO codes, haven't found any blown fuses yet, etc...
Thanks!
Have a nice day, evening...
God Bless,
Ed
ELS is offline   Reply With Quote Quick reply to this message
Old 09-01-2010, 09:31 PM   #3 (permalink)
My car works great again. Cleaned up the ground connections and the fuel pump is humming like it should and everything else works great.
Old 09-01-2010, 09:36 PM   #4 (permalink)
The aerio is easy to test and the coils are a quick check as well, for those wondering these cars do "NOT" have timing belts and don't let anybody tell you other wise. They are driving a "PAIR" of chains which reduces the weight of the drive mechanism and unless one completely broke which would shut down the engine you have no slippage here like belt systems in other units. And the belts on the outside are auxiliary drive belts not timing.
Old 09-01-2010, 10:22 PM   #5 (permalink)
ELS
ELS's Avatar
Arrow
Just the type of information I'm looking for....
I sent you a PM, and an e-mail.....
(I NEED MY CAR RUNNING and DRIVEABLE - ASAP......)
Thanks!
God Bless,
Ed
Old 09-01-2010, 10:37 PM   #6 (permalink)
lumpylarry's Avatar
not totally true.. this is a world wide forum..
in some countries, the aerio runs a 1.6L engine which uses a timing belt.
2008 suzuki SX4 sport sedan 5spd FWD
2007 suzuki boulevard C50 SE
2001 suzuki swift 1.3 5spd blue
Old 09-01-2010, 11:02 PM   #7 (permalink)
I thank that man for a clarification before I helped somebody goof up their car. It can matter what country you got your car in. I have the Suzuki service manual for the 02 Aerio that is sold in the United States. Outside of that the engine ID would be the first place to check for individual component assignments.
Old 09-01-2010, 11:17 PM   #8 (permalink)
ELS
ELS's Avatar
Arrow
Also, the ground connection(s) I would be looking for are visible from underneath, rear of car?
If I crawled under the car, looking in the general direction of the rear seat floorboard area, where can I expect to locate this main (black) ground wire.?
So, does this snap over a thread, like a connector grommet.?
Is it held in place on the gas/fuel tank (sending unit/fuel pump) cover plate. (For lack of a better description.)?
Thanks!
God Bless,
Ed
Old 09-01-2010, 11:18 PM   #9 (permalink)
bill16507's Avatar
bill16507 is on a distinguished road
Default Check ground on throttle body to chassis
My Aerio had a bad ground connection from the throttle body to chassis. The ground had a plastic connection that went bad, so I removed the ground and replaced it with a heavier gauge wire to connect the 2 points.
Don't know if this helps good luck.
bill16507 is offline   Reply With Quote Quick reply to this message
Old 09-01-2010, 11:24 PM   #10 (permalink)
ELS
ELS's Avatar
Arrow
I am surely open to all possible solutions, I need to have my car running again, and asap...
I have no other vehicle, and when you pay insurance and etc. on a car, one certainly wants to be able to use it and drive it..
Hope whatever I need to do (try out) / check for and such will fix it...
Thanks again for all input...
God Bless,
Ed
