timing chain = engine removal - Suzuki Forums: Suzuki Forum Site
Old 07-04-2010, 10:22 PM   #1 (permalink)
PATVAC is on a distinguished road
Default timing chain = engine removal
Hi, my chain is making some noise, i was a bit suprise when i read the first line from Mitchell saying remove engine. I want to know if it's possible to do the job with engine in place
thank you
PATVAC is offline   Reply With Quote Quick reply to this message
Old 07-05-2010, 08:30 AM   #2 (permalink)
lumpylarry's Avatar
yes its possible.
its a bit tight to sneak the timing cover past the idler stud but ive done it many times..
2008 suzuki SX4 sport sedan 5spd FWD
2007 suzuki boulevard C50 SE
2001 suzuki swift 1.3 5spd blue
Old 07-06-2010, 01:14 AM   #3 (permalink)
Originally Posted by lumpylarry View Post
yes its possible.
Have you tried this in the SX-4 yet? There appears to be a lot more room too compared to Aerio.
What do you do to get the stud past?? Jack the engine up a bunch or what?? I' wan to try this sometime.
Jeff L. is offline   Reply With Quote Quick reply to this message
Old 07-06-2010, 04:18 AM   #4 (permalink)
Elmo Christian is on a distinguished road
Hi..You can remove your noisy engine by the following way..Bolt a heavy chain to both sides of the motor and bring the engine hoist around. Pull the motor out of the car slowly, making sure the front of the motor is higher than the back. Make sure not to hit the car as you bring the engine away from the car.
BMW Accessories
Elmo Christian is offline   Reply With Quote Quick reply to this message
Old 07-06-2010, 07:52 AM   #5 (permalink)
lumpylarry's Avatar
yup, once the front mount is all off, jack the engine until the ground wire on the throttle gets tight. unclip the wire, go one more pump.
that should give enough room.
it works on sx4 too. i think you're right about sx4 having a little more room..
Old 07-15-2010, 09:54 PM   #6 (permalink)
Rainking157 is on a distinguished road
The other way, albeit redneck, to remove the engine...put car on jackstands, unbolt engine/transaxel from car with ATV jack w/straps around engine under it, lift front of car with chaintackel and lower jack. Then take engine to where ever you want to work on it with the jack, for head work leave it strapped to the jack; for engine overhaul just strap the transaxel and take the engine off to work on it. We used some sturdy tubular scaffolding with a two 6X6's across to hang the chaintackel and support car.
Rainking157 is offline   Reply With Quote Quick reply to this message
Old 07-18-2010, 11:14 PM   #7 (permalink)
Devilsword's Avatar
Devilsword is on a distinguished road
before you remove the engine pull the valve cover and take a look at it and the chain guide. these engines have a little noise stock, so don't make harsh moves without really knowing.
2006 sport mind edition Aerio SX MODS INCLUDING AEM Intake, Mandrel Exhaust, Racing Dynamics Engine Comps,NGK Ignition, Custom Engine Electronics, KSPORT COILOVERS!!!!, SWT Strut Bars, Custom Brakes, Custom Transmission, Custom MAF/IAT Tube, 160 degree thermostat, Fujita air filter, MaBo ground wires,... To much to fit check out my car domain http://www.cardomain.com/ride/2349923
For all things Aerio the best forum is http://www.aeriostyle.com/forum/index.php
Devilsword is offline   Reply With Quote Quick reply to this message
Old 08-31-2010, 11:04 PM   #8 (permalink)
Default run good 2 days no sound like crap
Hi , i have order timing chain by Eba? , install it without removing the engine, i went really good. Check timing marks, rotate 2 révolution marks align again. I start the car, ran really good, my noise was gone i was really hapy. Happyness was for 2 days only, Now engine is really noisy. any tips or suggestion to check for, any inputs on kit i bought, is jobber crap for these car???. I dont fell to pass about 8 hours again just to remove and check are they any quicker way I have done multiple timing chain and timing belt before
