2003 Aerio A/C compressor question - Suzuki Forums: Suzuki Forum Site
Old 09-10-2019, 09:18 AM   #1 (permalink)
piccolo113 is on a distinguished road
Question 2003 Aerio A/C compressor question
Can anyone tell me where the fuse or the relay for the A/C compressor clutch is? I know where the two fuse/relay boxes are behind the battery, I just don't know which fuse/relay to pull to stop the compressor clutch from engaging.
My A/C has been in disuse for so long that it makes very loud noises and makes the whole car vibrate when it engages, and I would like to just disable it. This wouldn't normally be an issue in most circumstances, but because it engages automatically when I set the interior air to defrost my windshield, it makes driving during the wet and cold seasons a bit of a pain.
...Also, repairing/replacing the A/C compressor is kind of out of the question as I cannot afford to do so.
piccolo113 is offline   Reply With Quote Quick reply to this message
Old 09-10-2019, 10:35 AM   #2 (permalink)
aquanaut20's Avatar
disconnect the plug at the compressor, if you cannot find the fuses..
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 09-11-2019, 12:47 AM   #3 (permalink)
Yeah. I just don't have any way to lift the darn car up so I can get under there and do that at the moment.
Old 09-11-2019, 01:01 AM   #4 (permalink)
you don't have a jack in the car to change a tyre? use that and a couple of bits of wood to block it in case it slips off the jack
and the fuse box cover is labelled with fuse descriptions
2008 Swift M15A
Old 09-11-2019, 06:09 AM   #5 (permalink)
Said fuse descriptions are "relay 1" "relay 2" etc. They do not actually say which piece corresponds to which part of the car.
Yeah, my tire jack is in the trunk....but that little thing isn't meant to be safe enough to crawl under a car with. Add a touch of claustrophobia to the mix, and the thought of that being the only thing holding up the car with me under it is terrifying beyond belief. :/
Old 09-11-2019, 12:10 PM   #6 (permalink)
if it looks like the one in this pic, relays are at the end as shown.
relay labelled as "1" in the pic is the compressor relay, Diagrams from a 2003.
2003 Aerio A/C compressor question-2003aeriofuseboxdiagram.jpg.jpg
2008 Swift M15A
Old 09-11-2019, 09:30 PM   #7 (permalink)
Well, the diagram you gave me doesn't correspond to my vehicle, but I went and tried anyway. I pulled every fuse and every relay in both relay/fuse boxes one by one and started up the car to test the defrost setting for the fan and the AC button. Nothing disabled it. Though there is a big 80A fuse I couldn't pull out (I figured if it's that difficult to pull out, I probably shouldn't try any harder).
I also took a look under the car and can't see anything without it being lifted up. The A/C compressor is behind the tire, as far as I can tell, and of course there's that lining that covers the bottom and wheel-well side of the engine compartment. I think there's just straight up nothing I can do to disable the darn thing with what I have.
Old 09-11-2019, 09:34 PM   #8 (permalink)
there should be an a/c button on the heater control panel, does that not work?
and one of the relays under the bonnet will control the compressor. the big 80a fuse is the main one for the car and is bolted in.
2008 Swift M15A
Old 09-11-2019, 10:11 PM   #9 (permalink)
I....what? What did I say that made you think that? No, the button works just fine. My issue this entire time has been wanting to make it so the AC compressor can get no power as it is clearly damaged.
Like I said, I pulled every single one out, one by one, and started up the car and tested each time. The compressor engaged every single time. None of the relays or fuses being pulled stopped it from engaging. I'm telling you this as a *fact* because I just did this a few hours ago.
I'm sorry, I know you're just trying to help. I'm super frustrated with the situation and how even simple trial-and-error testing hasn't resulted in anything useful.
Old 09-11-2019, 11:46 PM   #10 (permalink)
if you press the a/c button on the heater control panel so it is not illuminated, that disables the A/C compressor from activating when you select defrost, or turn the fan on in the car
2008 Swift M15A
