Tire Tips Fact Sheet - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Technical > Suspension, Wheels and Tires
Old 08-17-2010, 01:14 AM   #1 (permalink)
vitun is on a distinguished road
Default Tire Tips Fact Sheet
Hello Friends
just got lucky in holding Tyre tip worksheet and thought to share it here ..... which will Help all you members out there .
1. Always keep tires inflated at levels listed in owner manual. To ensure proper pressure reading, check tires when they are cool. Air pressure should be checked about once a week for routine driving.
2. When possible, start and stop vehicle slowly and decelerate around corners. Also, avoid squealing tires. This will help prevent unnecessary wear and tear of your tires.
3. Always drive the recommended speed limit. Increases in speed cause higher tire temperature, thus extra tire wear.
4.Make sure your tires are properly balanced and rotated. This should be done every 5,000 to 8,000 miles, or as recommended by the tire manufacturer.
5. Slow down or avoid curbs, potholes, and any debris in roads; also slow down on rough roads. Failure to do so may throw off your vehicles alignment and cause unneeded damage and wear to your vehicle’s tires.
6. Make sure your tires are of the recommended size for your vehicle. If your tires are undersized, they could potentially lose up to 10% of their life and also cause your vehicle to waste gas.
7. Having your vehicle properly aligned is important in maintaining tire quality. Vehicle alignment should be checked often, especially if you notice your vehicle ‘pulling’ to one side or another, or if you notice irregular tread wear on your vehicle’s tires.
8. Tread depth is another important factor for tire maintenance. Tires should have a minimum tread depth of 1/16th of an inch. A quick easy way to test tread depth is the “penny test”.
Place a penny within the tire’s treads and check to see if Lincoln’s head is visible. If Lincoln’s entire head is visible, then it is time to replace the tire.
9. Do not overload your vehicle. Overloading your vehicle may jeopardize its ability to operate safely. Check your owner manual for vehicle’s maximum load.
10. In general, each of the tires on your vehicle should be the same type, size, brand, etc. There are some exceptions to this rule, such as high performance vehicles. Check with your tire dealer if you have any questions.
11.When its time to replace your old tires, you may want to consider purchasing retread tires.This will increase the markets for reuse of old tires and help with limiting the number of old tires that are disposed.
12.If you store your tires for extended periods of time (such as winter tires), store them in a dry,cool place. Lay your tires flat and stack them no more than four high. It is also highly recommended that you get storage bags for each individual tire. You should be able to purchase storage bags at any tire dealer.
Hope this Helps
Wheels
vitun is offline   Reply With Quote Quick reply to this message
