Reno / Forenza Tech - Suzuki Forums: Suzuki Forum Site
Old 03-22-2007, 08:41 PM   #1 (permalink)
TTGOTH's Avatar
TTGOTH is on a distinguished road
Default Reno / Forenza Tech
To any Suzuki Tech guys / Galls. I want to turn the Rev Limiter off or just do away with it. Any ideas as to what wire or any code that can be used when reprogramming? I do not care about losing my warranty, I just want to rev to 8K or higher....
[url]http://tt-goth.blogspot.com/[/url]
TTGOTH is offline   Reply With Quote Quick reply to this message
Old 03-23-2007, 03:10 AM   #2 (permalink)
kinkyllama's Avatar
I doubt our engine will safly rev that high...actually I know it won't. Not to mention it doesnt make any power that high. What do you have planned?
I think an MSD DIS-2 is your cheapest way to remove it though, but I'm not even possible if it can do that.
[size=2][b][url=http://autoinsurances.wearecares.net]Best Auto Insurance[/url] | [url=autoprotection.wearecares.net]Auto Protection Today[/url] | [url=trade-in.wearecares.net]FREE Trade-In Quote[/url][/b][/size]
Old 03-25-2007, 05:53 PM   #3 (permalink)
TTGOTH's Avatar
When I boost the compression add the headers and exhaust system I should be able to have a good power to 8k. The MSD DIS-2 has been in the back of my mind, I just wanted to go the less costly route. Do you know anything about the rods in this engine? Is that the akelis heal of the engine? The crank seems to be very strong from the looks of it.
Old 03-25-2007, 11:39 PM   #4 (permalink)
kinkyllama's Avatar
I think the DIS-2 is your cheapest route...its not that bad easy. You can find them used pretty easy.
Don't know much about the rods as I knew they wouldnt handle the power I wanted. Though as far as boost is concerned 12psi is pushing it a bit....I think, I remember something around those lines.
The crank is pretty strong, two of the three guys that know our engines best on this side of the World said the stock crank would handle my goal of 335crank hp
Old 03-27-2007, 09:09 PM   #5 (permalink)
TTGOTH's Avatar
I found a DIS-2 for $275.00 used. I might let it pass. I wanna see what the headers and exhaust does first.
Old 03-28-2007, 02:08 AM   #6 (permalink)
kinkyllama's Avatar
Well since it wont do much for performance untill you have the headers and exhaust just keep an eye out for one going stupid cheap. Still the DIS-2 doesnt seam to help much unless your motors really built up.
Old 06-06-2007, 11:54 AM   #7 (permalink)
Legion is on a distinguished road
If you decide you want to try to rev past the redline limit fo the engine, I would suggest some other work done as well. Such as, shot peening and cryotreating the rods, forged pistons, knife edged crank and a full balancing of the crank, rods, pistons. The faster that engine moves the more any imbalances (however small they are) can cause problems.
So, it's not like the crank isn't strong enough to support the power of the engine, it's that the crank and other parts shouldn't be going quite that fast. I would do some research on it and see what the total rpm capability is of these engines...before revving that high.
I know on another car I used to drive, even though the redline was 8k, if you revved to 7.5 or more, the valve springs would float and move causing a need for a complete rebuild of the head....just watch out...
I am the one and only sneaky ninja! :ph34r:
Legion is offline   Reply With Quote Quick reply to this message
Old 06-07-2007, 08:37 AM   #8 (permalink)
jaxreno's Avatar
jaxreno is on a distinguished road
I completely agree with Legion. To add, however, you are going to need to do some head/valve work to achieve anything that high as well. I don't forsee headers, exhaust and intake opening up enough flow to make any feasable gains by revving that high. The engine needs to be able to move the extra volume of air smoothly in order to use it. Also the stock camshafts are not going to be able to make use of it. I suggest a new intake with a larger plenum volume, a larger throttle body, a cam with a higher lift and duration, porting and polishing, and possibly larger valves to make the higher RPM worth it. Just my two yen!
[IMG]http://i40.photobucket.com/albums/e241/gregorymana1234/JAXRENOSIG.jpg[/IMG]
"Oversteer is when the passenger is scared; understeer is when the driver is scared!!"
"Thats why you can't hit 120. Get a set of better tires with a high enough speed rating and you should hit it." -Jurupa
jaxreno is offline   Reply With Quote Quick reply to this message
