Poet and Polish - Suzuki Forums: Suzuki Forum Site
Ľ Wheel & Tire Center
Old 01-15-2007, 08:01 PM   #1 (permalink)
TTGOTH's Avatar
TTGOTH is on a distinguished road
Arrow Port and Polish
I just ordered a port and polish kit from Summit Racing. I will be doing a port and polish on both the intake and exhaust manifolds. I'm also going to see about porting the throttle body to help with air flow. I do need to see if anyone has a contact for getting a piston and rod. I need this so I can find pistons and rods to bump the compression up to 11.1. My goal is to have 200whp, With this and other bolt on's. I was told that if I polish the combustion side of the valve cover to a mirror finish that it will reflect most of the heat back to the combustion chamber. Thus giving me a cooler running engine with more power. With 11.1 compression I will have to run better fuel, So the fact that I have been running e85 for the past 6 tanks full with no problems I should do fine. The e85 is a home brew that my uncle makes, He uses it to drink I use to go. I will post pics on every step I take, I will also include pics of my screw upís so you can do it correctly. Other bolt onís will be the UD Pulley that kink sells, And cam gears from the GM Performance catalog. The muffler Iím going to swap out for a lighter one and mount it in place of the resonator. I have out grown the keg can mufflers.
[url]http://tt-goth.blogspot.com/[/url]
TTGOTH is offline   Reply With Quote Quick reply to this message
Old 01-16-2007, 12:21 PM   #2 (permalink)
kinkyllama's Avatar
Depending which model TB you have you probably won't have anything you can do to it... I think all forenzas/renos came with the better designed one. Also from what I've heard the exhaust mani isnt bad...but the intake mani is. Let us know how it goes, I've been meaning to port the intake mani for months.
What are these cams your talking about? Whatever they are I wouldn't think they're a direct fit...otherwise I know a few people that probably would have gone after them rather than some others. If you need cams I can get them, they are just expensive.
Also I'll look into higher compression piston and rod combo for you.
Danny
[size=2][b][url=http://autoinsurances.wearecares.net]Best Auto Insurance[/url] | [url=autoprotection.wearecares.net]Auto Protection Today[/url] | [url=trade-in.wearecares.net]FREE Trade-In Quote[/url][/b][/size]
Old 01-16-2007, 12:32 PM   #3 (permalink)
kinkyllama's Avatar
PM sent about rods/pistons
Old 01-16-2007, 02:16 PM   #4 (permalink)
TTGOTH's Avatar
The cam gears might be a direct bolt on from what I can see. As per RML, They state the the WTCC Lacetti uses the Ecotec block and internals. But they get the top end from GMDAT. I'm not sur if he is talking about the top end that we have, So I will just compare the CAD drawings of the 2 to see if they are the same as they state. This is a link to the RML site. RML. I might go for the pistons and rods you P.M'd me about. Push come to shove I can always go with a thinner gasket to make up what I want to have. I did look at the exhaust manifold when I pulled the cat off. It's not bad, But some areas do need to be ground down to help the flow out. I have yet to look at the intake, But most cast intakes I have seen are rougher on the inside than the outside. Or I might just go with an idea I’ve had for a new intake manifold. I'm buying a new welder so I was thinking about trying to do a twin throttle body manifold using stock throttle bodies. I think I said this before in another thread. The one thing I can say about this engine is that it love to breath, Even if the ECU does not know it!!!!!!!!! Thank god I live in florida, We have no emissions inspections to deal with. But still the cam gear thing might be a waist of time, I will just have to see.
Old 01-16-2007, 02:57 PM   #5 (permalink)
kinkyllama's Avatar
Well If the cams don't come through for you lemme know. I was going to bring over three sets, then have to mod them slightly. One sets for me, the other will go on ebay or something.
Just checked...cams arn't stupid expensive....should be under $350 for some really nice looking cams
Old 01-16-2007, 03:55 PM   #6 (permalink)
TTGOTH's Avatar
Shit, Thatís not bad. If it turns out that the cams Iím looking at are a pain in the ass, Then i might just grab a set from you. I wish I could find some detailed drawings with measurements for this engine. It would make things a little easer for us.
Old 01-16-2007, 07:35 PM   #7 (permalink)
TTGOTH's Avatar
CAM GEARS.
The part numbers on the Reno and Forenza cam gears are the same as the Opel X20XEV Engine. Looking at a side profile of the Opel engine without the cam cover the cam gears look to be identical down bolts holding them on. I'm selling the civic "thank god" so i will be going down to the Chevy dealer on Friday. They have a set of adjustable cam gears for the X20XEV engine, If it fits then i will buy them and post the info. BTW, The cam cover is VERY brittle. It cracked in half, No big deal it looks better. P.S. The X20XEV engine i am referring to was used from 1995 to 2004 i think?????? I will post pics later from photobucket....
Intake cam- 90531683
Exhaust cam- 90411776
Old 01-16-2007, 10:13 PM   #8 (permalink)
kinkyllama's Avatar
Originally Posted by TTGOTH
CAM GEARS.
Cool...make sure it has the signal pickup...our engine needs it to run well but will run without it...it just hesitates and doesnt do so well on higher rpms.
Old 01-16-2007, 10:19 PM   #9 (permalink)
TTGOTH's Avatar
The high RPM is what i like about this car, We must keep her revin.
Wow, Revin Kevin???? Um never mind. Damn Icehouse
Old 01-16-2007, 10:27 PM   #10 (permalink)
TTGOTH's Avatar
Cam Gear pics. The pics suck, It's not Kodak....
http://i100.photobucket.com/albums/m...h/PICT0005.jpg
http://i100.photobucket.com/albums/m...h/PICT0002.jpg
http://i100.photobucket.com/albums/m...PICT0006-1.jpg
http://i100.photobucket.com/albums/m...h/PICT0001.jpg
http://i100.photobucket.com/albums/m...h/PICT0004.jpg
