TBI Conversion for RX 7 - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > General > Other Cars
Old 03-29-2010, 12:56 PM   #1 (permalink)
Default TBI Conversion for RX 7
I know is off the Tracker subject but I am wondering if anybody can share some light or knows some about this...
One of my co-workers has an 82 RX7 and we are exploring the possibility of a TBI. I am wondering, it was made a TBI without ignition control? The problem that I am facing is, the Wankel Engine ignition sequence is very different from any piston engine. So I am looking for a simple TBI that does not regulate the Ignition Timing.
There is such animal...?
Other Toys...
2016 Chevrolet Colorado LT 3.6 V6 G80 Locker
2009 Pontiac G8 GT 6.0L
2007 VWL Beetle 5 Cly
2003 Chevrolet Impala 3.4L
2001 Pontiac Grand Am SE 3.4L
[url=http://s784.photobucket.com/albums/yy129/spamme4444/?start=all]Tracker Photos[/url]
Richard Craneum is offline   Reply With Quote Quick reply to this message
Old 03-29-2010, 01:09 PM   #2 (permalink)
Banned
ah there are PNP RX7 Custom ECU kits.
why re invent the wheel. curious.?
and did you know detonation on a wankel blows the apex seal ,so fast , in the blink of an eye.
you have now idea how hard that is to stop !!!!
Old 03-29-2010, 01:15 PM   #3 (permalink)
The thing is...
It has a factory Mazda 4BBL Carb and is much harder to keep up. Too many vacuum lines and other junk that creates a lot of headaches. So we are wondering, why not using a TBI? We are all aware, the Mazda Wankel it has an oil jet in the carb to keep the Apex Seals happy. So that part is easy to do, like the mods for Holley carbs. Also, these engines uses Petroleum Based oils and Synthetics should be avoid at all cost (will eat the Apex Seals).
In reality, is not a step back, is just few steps forward, perhaps from 82 to 87?
We have not done anything yet. Just exploring the possibility.
Other Toys...
Old 03-29-2010, 04:52 PM   #4 (permalink)
Guest
Why not use the EFI set up from a later RX7? The RX7 ECU was hacked years ago if you need to retune it.
Old 03-29-2010, 05:46 PM   #5 (permalink)
Banned
rx7
i think this is one of the motors on every single ECU maker.
82 motor , very very old, long in tooth, how much you going to spend on that.
and on motor to make it worth the effort?
and stock RX7 EFI is like , unobtainium here. where can you find that....?
join the RX forum and find out, last place is here.. this is a suzuki site.
google is your friend. ( but you did not mention the purse and that dictates all)
Mazda RX7 AEM ECU
How To Megasquirt Your 2nd Gen RX-7: Remove Stock Wiring and ECU
Haltech Sport 1000 plug&play EMS ECU 4 86-88 Mazda RX7 : eBay Motors (item 110443568027 end time Apr-06-10 11:45:58 PDT)
pretty much std price.
$1000 + 500 tune or PNP for $1500
pretty hard to beat and like i said, it just hates detonation.
and how to do that TUNING is the TRICK.
oops , boom, got another motor.?
get PNP and be happy
or
get (find ) up scale Stock future RX7 EFI.
and congrats one of the only RX7 posts ever.
Old 03-29-2010, 05:51 PM   #6 (permalink)
Banned
Aftermarket ECU - MP3Car.com
Mazda RX7 | Owners, Parts, Repair, Performance, Mods, Wheels - RX7Club.com
Rx7Forums.com - Powered by vBulletin
Old 03-29-2010, 06:16 PM   #7 (permalink)
Banned
TBI is not some magic path to a solution
you need a tuned ECU for your motor, TBI or what ever .
for its desplacement and volumetric efficiencies.
so that boils down to , who's ECU can you afford.
How much is in this EFI RX7 purse?
Old 03-29-2010, 06:50 PM   #8 (permalink)
The car is 1st Gen RX7 so is all mechanical, the type of systems that I hate, early 80s tech
We were just talking about it, what if, instead of rebuilding the stock 4 BBL carb, install a simple TBI that is more reliable, drives better, more efficient and less polluting. We do not want to modify it for performance, just keep it pretty much stock. We have the rebuild kit for the carb if we can not find a suitable TBI.
Also, I went through the RX7Forums and I found some interesting things, like a TBI side draft style systems.
I found a pretty neat mod....
Is for the Oil jet by the intake. Instead of using Engine Oil as it was design it, uses 2 Stroke oil and you can use Synthetic for the engine. According to the site, Synthetic oils are not design to be burnt, so they eat the seals on the Wankel, but using dirty crankcase oil is not good either. So using 2 separate oil systems you get the best of both worlds. The ratio is 1:100 so a Gallon of 2 Stroke Oil it will last like aprox 25 Fill Ups, so that is what they claimed.
Other Toys...
Old 03-29-2010, 08:33 PM   #9 (permalink)
Banned
TBI IS EFI
MPI is EFI
A throttle body is just a block of aluminum with an air valve.
EFI TBI is a complex ECU System.
look at our TBI and MPI note only 3 missing injectors., and all else the same.!
And all tuning is quite unique in the 2. ( 8v and 16v ) .
OIL ,OMG dont say oil or the witch hunt starts..... LOL !!!
actually all crank case oils are ment to be burnt.
the only issues is ,how fast. ( 2 stoke oil a classic case)
all motors let oil slide up past the ring (oil control ring ) then into the top 2 rings.
where it then burns.
must be something about the designed of the apex seal. not liking syn oil. (i dont know)
the other problem there is , that there are oils that are syn oil and not labled as such.
syn oil can be mfg 2 ways.
long chain reduction (dino to syn) ( hydrocracking)
or
short chain to long (add hyrdogen)
the results can be and are the same. ( huge law suit for that; proved that)
The details about these facts are at Chevron.com, all the details.
many oils , the only difference it he additives in the oil , can be big differences.
The TBI has 1 or 2 injectors.
the reason for 2 is if the main injector cant handle idle ( main becomes non linear at low end)
forget idle. lets talk off idle where all the fun happens....
the main injector needs the same fuel controls as a mpi 4 injection system.
with all the other sensors. ( i just made one with a MS V2 megasquirt TBI)
the whole process is the same for TBI and MPI but one step. ( done automatically
in the equations,) Most cheap ECU MPI systems just do gang injection
so are no better than TBI save he close proxemity to the valves. (intake)
non sequential.
Biggest difference is the smaller injectors. on MPI and coding that in.
TBI an MPI
all have fuel table
Spark Advance tables
VE tables.
and seperate ,cold ,warm and hot tables.
all must be programmed and tuned a dyno.
or buy a PNP kit that has it already done for you.
A TBI is not a carb, nor is it more near a carb, not at all, not even close.
but sure TBI is physical work less work than 4 injector pockets. and sure totally the way to go on a rotary.
You have 3 choices (systems) TBI,MPI or N-Alpha ( aside from carbs)
Dont get me wrong there are -ALPHA systems that have only 2 parts.
a TPS and a TBI , a black box , to control the injector.
it is real crude and will blow a motor fast.
and really dirty at low RPM, black exhaust clouds dirty.
there are race cars that use this system, that never ever go under WOT.
in this case they work ( one AFR , WOT and RPM?TPS based) no map, no maf, no nuttn
Drag cars?
or other fast track cars can have this. and a closely guarded secret by the users.
there are huge sections over at MS forum for this usage.
read about this crude injection form here.
Electronic Fuel Injection Mass Flow vs. Speed Density- Car Craft Magazine
Old 03-30-2010, 02:53 AM   #10 (permalink)
Guest
The Norton rotary used two stroke oil.
