Alpine HCE-TCAM1-WRA - Suzuki Forums: Suzuki Forum Site
Old 08-01-2017, 09:35 PM   #1 (permalink)
pjf
pjf's Avatar
Gallery: 118
pjf is an unknown quantity at this point
Default Alpine HCE-TCAM1-WRA
I've just had Crutchfield install an Alpine HCE-TCAM1-WRA rear camera, backup light and stop light unit on my 1989 Suzuki Sidekick. It fits in the center of the rear spare tire. I wish that I could post a picture but photo uploads have been busted for a while. You can Google "Alpine HCE-TCAM1-WRA" to see it.
This Alpine unit is meant for a Jeep Wrangler with a 5x5" bolt pattern. However, the elongated holes of the mounting plate also fit the 5x5.5" bolt pattern of a Suzuki Sidekick. It is a perfect drop-in fit!
Mounting the rear backup camera at the center of the spare tire has advantages over a license plate mount as the spare tire is closer to the center line of the car than the license plate.
The Alpine unit can be disconnected to allow the removal of the spare tire. I believe that this is the best choice for Jeeps or Suzukis with the tailgate spare tire mount!
1989 Suzuki Sidekick JX 2-Door Convertible
Engine: 1.6-liter & 8-valve (2014)
4WD 5-speed manual transmission & transfer case
VIN JS3TA01C4K4114731
Mods: 16" x 7" wheels, rock sliders, tubular receiver bumpers, Doug Thorley exhaust header, OME suspension, Dynamat & SiriusXM
pjf is offline   Reply With Quote Quick reply to this message
Old 08-01-2017, 11:23 PM   #2 (permalink)
Donewrken's Avatar
What's even better than a picture?
Nice unit!
Thanks for sharing.
Don
I'm here in the USA.
1991 GMC K2500 4WD 454 Xcab
1997 Trans Am LT1 auto
Old 09-01-2017, 06:44 PM   #3 (permalink)
pjf
pjf's Avatar
Gallery: 118
The 3 elongated holes on the mounting plate allows the Alpine HCE-TCAM1-WRA to fit both the 5x5" bolt pattern of a Jeep spare tire and the 5x5.5" bolt pattern of a Suzuki spare tire.
Here is how it looks on my 1989 Suzuki Sidekick.
In my humble opinion, the Alpine HCE-TCAM1-WRA is a better fit for the Suzuki.
  1. It is a firmer fit because the Suzuki bolts align with the outer edges of the elongated holes.
  2. The Suzuki electrical interface is standard with no need for the special interface required by the Jeep factory radio.
Old 09-24-2017, 09:04 PM   #4 (permalink)
pjf
pjf's Avatar
Gallery: 118
Default Lug Nuts
Since the Alpine HCE-TCAM1-WRA was made for a Jeep, the lug nut that secures it is threaded for a Jeep. There is a black rubber cover over the lug nut at the center of the Alpine HCE-TCAM1-WRA. The lug nut secures the unit to the mounting plate. When the cover is removed, the lug nut is revealed.
The thread size for a HCE-TCAM1-WRA lug nut is 1/2" x 20 where 1/2" is the bolt diameter and 20 threads per inch represents the pitch. A 60-degree tapered cone seat is required to properly mate with the HCE-TCAM1-WRA. The length of the lug nut should not exceed 1.5-inch. Otherwise, the lug nut will protrude too far to be covered by the rubber Alpine cap.
On the right is the original lug nut that comes with the HCE-TCAM1-WRA. On the left is a locking lug nut for a Jeep that I purchased from Gorilla Automotive.
The Gorilla Automotive model 21681SD small diameter lug nut lock fits the HCE-TCAM-WRA perfectly! Other lug nut locks may work but the model 21681SD is the one that I have installed and can attest to.
Old 09-24-2017, 09:41 PM   #5 (permalink)
That's a neat idea for a backup camera, but as far as using it on a Suzuki goes, you need to be aware that high mount stop lights are required to be on the vehicle center line - I've never seen a Suzuki that had the spare wheel mounted on the vehicle center line.
Old 09-24-2017, 10:11 PM   #6 (permalink)
Donewrken's Avatar
He never said anything about the spare wheel being mounted on the vehicle's center-line.
What he did say was that it was closer to the center-line than the license plate holder & that it is in the center of the rear spare tire.
(I've never seen any other location for a spare tire holder other than inside)
Still, I am happy with my license plate-light mounted camera.
Don
Old 09-25-2017, 07:24 AM   #7 (permalink)
Don - in addition to being a backup camera, the Alpine unit is also a high mount stop light - that's the reason it needs to be mounted on the vehicle centerline.
Old 10-31-2017, 10:53 PM   #8 (permalink)
pjf
pjf's Avatar
Gallery: 118
Hmmm...
I'm not aware that Federal Motor Vehicle Safety Standard 108, Section 5.1.1.27(b), which governs the center high-mounted stop light (CHMSL), applies to multipurpose passenger vehicles or light trucks manufactured prior to 9/01/1993.
There is another CHMSL from Rampage that AutoZone recommends for my 1989 Suzuki Sidekick: http://www.autozone.com/collision-bo...ehicleSet=true. Unfortunately, the Rampage CHMSL will still be mounted off-center.
As for my Alpine HCE-TCAM1-WRA, I can disconnect the stoplight feature if it needs to be disabled. The backup camera and backup light will still continue to work. However, since my 1989 Sidekick is over 25 years old, my state does not even require annual safety inspections for it.
Old 10-31-2017, 11:43 PM   #9 (permalink)
Donewrken's Avatar
I do like your camera setup and the stop light as well.
I was showing mine off, more to display my wife's friends personalized license plate than anything else.
She had me take a picture of it the day she received them and I've "photoshopped" it in where ever I can.
It hasn't been deciphered yet unfortunately, or maybe that's a good thing.
LOL!!
I was pleased with my camera in that it was included along with the radio and
the ease of installation, it even had the 1" drill bit. Then only required one more hole for the wiring.
I'm getting ready to install one on the 94 but it's a surface mount and will
require some ingenuity - or another purchase.
This radio/MP5 player has the hookup & I already had the camera.
It was a bargain for less than $50 bucks, it's only the grocery getter.
With no inspections, I wouldn't think it should be an issue for you, same for me.
Don
Old 11-17-2017, 05:51 PM   #10 (permalink)
pjf
pjf's Avatar
Gallery: 118
This was my previous rear view camera. It was inserted into a hole drilled into the hubcap of the spare tire.
It produced a grainy picture and sometimes did not work when it rained. When the spare tire was removed, the hubcap will hang loosely by the camera wire. I was afraid that a careless tire rotation worker may someday rip the camera and hubcap off the wire.
The Alpine HCE-TCAM1-WRA has a wiring interface that can be disconnected if the spare tire needs to be removed. The camera produces a much higher resolution picture.
