Air horn replacment - Suzuki Forums: Suzuki Forum Site
Old 01-16-2007, 07:52 PM   #1 (permalink)
Zipper's Avatar
Gallery: 28
Default Air horn replacment
I would like to start that this part of the forum is the closest fit to my question.
For Christmas, a friend of mine whent and got me an airhorn to replace my squeeky OEM POS horn. The question is, will the stock wiring for the horn work with an air compresser. Is rated as drawing 12v 40 Amp. 40 Amps sounds like alot for the small guaged horn wires. If I had to replace the wires, can I start from the relay in the fuse box? Vehical wiring is kinda new to me.
Zipper is offline   Reply With Quote Quick reply to this message
Old 01-16-2007, 08:34 PM   #2 (permalink)
netlos's Avatar
netlos is an unknown quantity at this point
use the existing wiring to control the relay only!!!(one should be supplied with your air horn kit).and run a new line to the relay(make sure you fuse it) and the other side to your horn,and ground horn accordingly.
[/IMG]
netlos is offline   Reply With Quote Quick reply to this message
Old 01-16-2007, 10:57 PM   #3 (permalink)
schoolpsych's Avatar
schoolpsych
he's right about the relay -- and the fuse. Your stock fuse won't handle the horn. The relay is like a switch -- on/off. That, your stock fuse can handle. You'll need a separate fuse, rated over 40, for the horn assembly itself.
I've wanted to replace the horn, myself... but I think I'd just do one that can bolt up and not have a separate compressor. Simple is good.
schoolpsych is offline   Reply With Quote Quick reply to this message
Old 01-17-2007, 12:07 AM   #4 (permalink)
Zipper's Avatar
Gallery: 28
I know that. I just wasn't sure the stock wires could handel it
Old 01-21-2007, 02:20 PM   #5 (permalink)
Gothalyptic is on a distinguished road
I run with a fire dept in the area here on a volunteer basis, I have no visible lighting or siren speakers, instead I have my red strobes hidden above the windshield inside same as the back window. Anywho, I have a train horn (3 h orn system) wired in my forenza. I actually disconnected the factory horn and used the wires for the relay only as stated above. In-line fuse from the relay to the air compressor with 6g wire (just to be safe) and it works flawlessly.
I'd concure with the above statement of using the wires for the relay only. they should handle the power.
Err on the side of caution though is my general rule of thumb.
Gothalyptic is offline   Reply With Quote Quick reply to this message
Old 01-21-2007, 05:33 PM   #6 (permalink)
Zipper's Avatar
Gallery: 28
thanks, I was planning on that. Where did you mount the copressor. Pics might be nice... help me get some ideas
Old 01-22-2007, 09:26 AM   #7 (permalink)
I'll grab some pics after work today.
Old 01-28-2007, 08:40 PM   #8 (permalink)
Zipper's Avatar
Gallery: 28
Ok, I got the wiring (10 Gage overkill!), connectors for the compressor,and some loom to protect formention wire.
Any idea what it'll take to hook it up to my origonal relay? Any connectors, or is it something else
Old 01-30-2007, 12:19 AM   #9 (permalink)
zerocool is on a distinguished road
ok or u could be like me and by the 25 dollar horns at pep boys w/ the mini compressor that hooks up directly to where the old horn went
zerocool is offline   Reply With Quote Quick reply to this message
Old 01-30-2007, 03:21 AM   #10 (permalink)
Zipper's Avatar
Gallery: 28
Yeah, but now I have 135 dB of simi truck power. Not the old horn.
"Scuse me, you kinda cut me off... sir?"
Now its like:
"NO! I"M A MAC TRUCK! MOVE YOUR SORRY LITTLE HONDA BEFORE I RUN YOU OVER LIKE ROADKILL!"
See? Its loud!
Anyways, the compressor draws alittle to much juise for the old wire .I guess I could use another relayoff the horn wire, but thats cheesy.
