Led alarm - Suzuki Forums: Suzuki Forum Site
Old 12-07-2006, 08:16 AM   #1 (permalink)
carbonciocc is on a distinguished road
Default Led alarm
Hi there I want to fit an extra flashing led to my 1995 Vitara to supplement the one with the alarm, I dont want to fit it in tandem but I want to fit it so that it comes on each time I switch of the ignition, but I cant find what becomes live, only when the ignition key is removed, hope this makes sense.
Regards Tony
carbonciocc is offline   Reply With Quote Quick reply to this message
Old 12-07-2006, 05:07 PM   #2 (permalink)
Zipper's Avatar
Gallery: 28
Just vampire clamp onto that ones power to run it in parralell
Zipper is offline   Reply With Quote Quick reply to this message
Old 12-08-2006, 09:27 AM   #3 (permalink)
Default LED alarm
Thanks for your reply but the trouble is the existing car alarm isn't working so I just want to rig up the dummie led so that it comes on when the ignition is turned off.
Thanks Tony
Old 12-08-2006, 02:24 PM   #4 (permalink)
Gothalyptic is on a distinguished road
Not working or not connected? If the alarm is receiving power, you can still vamp clamp the hot wire on the exsisting LED. If it's not receiving power you could relay off the battery to disconnect when the relay receives power from the ignition sense. When the ignition is powered off it'll trip the relay to provide power from the battery. There's an Alarm, Stereo and other electronics installer somewhere on this site, hopefully he'll chime in and give a much better explination or proceedure.
Gothalyptic is offline   Reply With Quote Quick reply to this message
Old 12-11-2006, 03:29 AM   #5 (permalink)
mydogsaysplease's Avatar
mydogsaysplease is an unknown quantity at this point
man for 30 bucks you could put in a working alarm a cheapo but it'd work unless you dont want a working one then I say use your trusty volt meter on your wires. the back of the fuse box under the dash is where to probee volts. and even just looking at them some are always on by their function.
though a fake led is not a deterent, dont kid yourself. hassle factor is usualy the best deterent, not pretty leds.
It could be that the purpose of your life is only to serve as a warning to others.
mydogsaysplease is offline   Reply With Quote Quick reply to this message
Old 12-11-2006, 07:35 PM   #6 (permalink)
zerocool is on a distinguished road
u should just rig a little light to a nine volt battery and put a switch on it...
zerocool is offline   Reply With Quote Quick reply to this message
Old 12-13-2006, 08:01 AM   #7 (permalink)
iROK is an unknown quantity at this point
I'm with the cheapo thirty dollar alarm; Save you a couple grey hairs in the long run.
iROK is offline   Reply With Quote Quick reply to this message
Old 01-05-2007, 06:22 AM   #8 (permalink)
Zodie is on a distinguished road
If you MUST fit a cheapie flashing LED, get one suitable for 12V use. Connect the LED positive to a 12v supply that always has power (radio memory, hazard lights, etc) and the LED negative to the radio switched positive supply. Ignition is on, radio has power, no flashing led. Ignition is off, radio has no power, LED has ground, flashing LED.
Zodie is offline   Reply With Quote Quick reply to this message
Old 01-05-2007, 08:14 AM   #9 (permalink)
Zipper's Avatar
Gallery: 28
You could, but that is very mickey moused
