remote wire in a 2003 aerio - Suzuki Forums: Suzuki Forum Site
Old 07-02-2006, 02:14 PM   #1 (permalink)
nemesis340 is on a distinguished road
Exclamation remote wire in a 2003 aerio
i just installed subwolfers and im not getting power i need to know what color the remote wire is on the factory wires
thanks
Ron
nemesis340 is offline   Reply With Quote Quick reply to this message
Old 07-02-2006, 03:11 PM   #2 (permalink)
Zipper's Avatar
Gallery: 28
I'm sorry, your in the FORENZA/RENO page. We have no idea about the colors.
Zipper is offline   Reply With Quote Quick reply to this message
Old 08-09-2006, 07:38 PM   #3 (permalink)
Loganator is an unknown quantity at this point
Heres the deal dude, normally you would tap into the automatic antenna, which when the radio is on gives a constant 12V to put up the antenna... since the Aero doesnt have an antenna (correct me if I'm wrong).. you cannot tap into this... the easiest way to solve this is to splice into the power cable (running to your amp) and install a toggle switch, and you'll have to turn it on and off manually... I can give you more detailed instructions if you need...
Loganator is offline   Reply With Quote Quick reply to this message
Old 08-10-2006, 07:50 AM   #4 (permalink)
TimMcCabe is on a distinguished road
FYI,
The Aerio does not have a switched power wire in the factory connector plug, the factory sub is always powered with the key on, it has a signal sensing circuit that switches it on when there is an audio signal present.
If you are brave, there is a switched 12 signal in the Ce-Net connector (the square plug you would connect a CD changer to).
There are 2 larger terminal connectors in the plug, one is ground and the other should be a switched 12volt.
Cheers,
Tim
TimMcCabe is offline   Reply With Quote Quick reply to this message
